Author Topic: Removing quarter window  (Read 2850 times)
mdz
« on: March 14, 2019, 03:46:38 PM »
Need advice in removing quarter window and mechanism 1969 RS. I have the mechanism out but cant figure how to get the window out. Thanks in advance.
Re: Removing quarter window
« Reply #1 on: March 14, 2019, 03:55:45 PM »
 My guess the process is the same for '67. On youtube there is a series by Scared Shiftless that has some excellent videos.
This one is for installing the quarter glass but maybe it will help to remove it: https://www.youtube.com/watch?v=KGY4-3_hoXc
 Once the window felts are removed and the mechanics loosened (3 nuts), the window stop arm removed, the frame should move enough while working the glass rollers out of the tracks.
mdz
« Reply #2 on: March 16, 2019, 03:39:11 PM »
Thanks  Mike , after I posted this I went to utube thinking there wouldn't be anything so specific as 69 Camaro 1/4 window removal, but I was wrong . The first hit was exactly what I needed. It wasn't the video you posted, but it was dealing with removal only. The pass side came out without too much drama, but the drivers side was more stubborn . I think the key is turning the bottom track bolt in to get the track tilted just right. Thanks Mike and utube.
