Author Topic: 68 396 Smog Pump Bracket  (Read 2690 times)
rod396
« on: February 26, 2019, 04:16:19 AM »
Hopefully someone can answer this;
On a '68 396 Smog system, I have been informed that there are 2 different designs for the main (mounted on intake manifold) mounting bracket, one which has the spot-welded diverter valve mounting bracket and one without?
Is this true? If so, which version was "early" or "late" - and when was the "early" version changed?
Thank you.
Re: 68 396 Smog Pump Bracket
« Reply #1 on: February 26, 2019, 01:55:45 PM »
The spot welded bracket is correct for all 68 Camaro big blocks. I believe the one without the diverter valve bracket was used on Chevelle and full size cars with automatics.
« Last Edit: February 26, 2019, 03:46:41 PM by bertfam »
