Author Topic: downpipe compatability with L48 stock exhaust manifold  (Read 13183 times)
ace
« on: February 21, 2019, 07:38:54 PM »
Hello CRG members:
Planning to return my 69 coupe to a transverse exhaust system.  The engine -an L48 - has stock exhaust manifolds (part nos. 3932376 and 3942529).  Current downpipe/intermediate pipe measures 2".  I would like to purchase a 2.25" system that came with the 69 Z28's.  So here are my questions:
Will a 2.25 inch system designed for Z-28's mate up with the stock exhaust manifolds on a 350 c.i. engine?  The point of concern is that the heat-riser valve advertised for 69 exhaust manifolds seem to come only with a diameter of 2 inches.  Did the 302 c.i engine  use a larger diameter (2.25 inch) heat-riser valve than the 350 c.i. used?
Thanks for the input
Ace
Re: downpipe compatability with L48 stock exhaust manifold
« Reply #1 on: February 21, 2019, 08:03:38 PM »
All '69 N10 dual exhaust systems are basically the same; big-blocks had different head pipes. One notable difference was the interim Z/28 system after the chambered recall-no resonators and the deep-tone muffler from '68. Around mid-April, Z/28s received the same muffler/resonator system as the others. As of May 19, chromed tailpipes were added.
Small-blocks used the same heat riser, 3887023.
crossboss
  • ^ New engine project
« Reply #2 on: February 21, 2019, 10:07:55 PM »
You may want to look into Magnaflow's  'Muscle Car' exhaust systems. They are a nice stainless mandrel bent set up. I believe the cost is around $495, and Summit usually stocks it.
1968 Olds 442 W-30
ace
« Reply #3 on: February 22, 2019, 02:10:30 AM »
WilliamL-48
Thanks for the help.  The Z-28 and the 350L-48 exhaust manifolds appear to have the same specs.  The only difference is in the part numbers for 1969.  The Z-28 with smog air injector tubes are essentially the same manifold as a 350 L-48 without the air tube holes.
Still not clear how a 2.25 pipe system can mate up to a 2" heat-riser, unless the 2.25 inch system uses a 2" downpipe.  In any case, I will be looking into the 2.25 inch system sold by on-line vendors like D and R, Rick's Camaro,  Camaro Central, Shaper Classic Renovations etc.
Crossboss, thanks too for the tip on the Magnaflow with Summit.  Reviews were very positive.  Price is $804 at summit for the 409 stainless with 2.5 inch pipes.  The Magnaflow muffler (#12468) is an transverse muffler that incorporates and X pipe.  Pretty cool.
Ace
X33RS
« Reply #4 on: February 22, 2019, 02:09:16 PM »
Nice to see Magnaflow came out with a transverse system.
You have 2 other options, both that I've used.
The cheapest kit is made by dynomax, their thrush 89021 kit that is $260 at Summit.  It's a regular steel exhaust with an aluminized coating.  Nice mellow sound.  Only down side is they don't offer down pipes that I've seen if you are running manifolds.
The other is from Pypes.  I've used this one a lot.  It's stainless steel, and the cheapest stainless kit I've seen.  SGF70 is for all F-body 1st and 2nd gen transverse setups.  Right now Summit is having a sale on it for $550.  Pypes also sells mandrel bent down pypes separately to work with exhaust manifolds to complete the systems if you don't run headers.
I run 3 of these systems, a little more aggressive sounding than the dynomax but still very tolerable and nice for cruising with no drone.
Here's a quick sound clip of this system on my Z.  I grafted in the factory tailpipes for a stock appearance, which also helped to subdue the sound level just a touch.
Idle
https://youtu.be/IZ0HlEY7b74
Cruise
https://youtu.be/7a3lMwoM-7c
« Reply #5 on: February 22, 2019, 04:55:38 PM »
Yes,2" valve to 2.25" downpipes on my Z's original exhaust. Seals via gasket.
Are you looking for an OE appearing, or performance transverse system?
Gardener for concourse quality, I believe D&R for a good system.
Personally,I don't see the benefits of a 2.5" performance exhaust behind a
a mild smallblock with exhaust manifolds.Street duty, under 4600 rpm, I think a nice replica 2.25 will do you.
That being said,,,a set of Doug's headers and Pypes transverse exhaust is on my wish list at Summit. 8)
« Reply #6 on: February 22, 2019, 05:32:43 PM »
Sounds nice x33,,and can still listen to Molly Hatchet on the tunes.
« Reply #7 on: February 22, 2019, 05:42:44 PM »
Does the Pypes system utilize the stock hanger location? Or can it?
X33RS
« Reply #8 on: February 22, 2019, 09:16:12 PM »
Yes stock hangers.  However it should be mentioned the rear tail pipe hangers worked after I adapted the stock tail pipes to the system.  Since the stock tailpipes are 2" diameter, and the hangers are designed for that.  The stock hangers wouldn't fit around the 2 1/2" tail pipes that come with the system.    Which was fine as my plan all along was to adapt stock tail pipes for a "correct" appearance.
For anyone interested as far as performance goes, I'll have numbers to post in a couple months on the Z from it's original born with exhaust system that was still on the car, to the Pypes system, that should be interesting.
  I did a bunch of testing on this years back on my Formula 400, with a reproduction Garner system vs an aftermarket 2 1/2" mandrel bent system.  Both transverse systems.  The bird picked up a solid 4 tenths ET and a little over 3 mph with just the exhaust, still running through the manifolds, didn't touch anything else.  The stock crush bend systems on these cars really choke them down, and even on a stock build I find it's probably the biggest, and easiest improvement made in ET and MPH, that is if you're into making these things run as good as they look.
crossboss
« Reply #9 on: February 22, 2019, 10:16:09 PM »
I agree. The 'stock' OEM systems are quite restrictive. I also changed to 2.5" exhausts (with cast manifolds, on a Ford no less) with the same improvement of 4-5 tenths with about 4 mph. This was on a dead stock engine/car. So, yes, go for the bigger 2.5", as you will be happy with the improvements/performance.
1968 Olds 442 W-30
« Reply #10 on: February 22, 2019, 10:46:50 PM »
Like I stated, basically what's the purpose of the car.I get these engines are pumps.
I'm assuming by his question that he's looking for an OE appearance.In which case a replica 2.25 will bolt up to his riser/manifold and suit his needs. If he's seeking performance,,well different reply🤔
« Reply #11 on: February 22, 2019, 10:57:19 PM »
And the style manifolds he is using flow just awful.
ace
« Reply #12 on: February 23, 2019, 05:20:46 AM »
Janobyte, Crossboss, X33RS:
Appreciate the discussion.   Weighing the two basic options:  stock transverse versus performance transverse.  Engine is completely stock original for all parts except cam (mild Comp Cam).  Stock heads were pocket ported to improve flow, but still using original intake and quadrajet.  Exhaust manifolds and water pump (sent back to New York for restoration) are original to the engine.  Stock manifolds are restrictive, but hoping to get some gain in flow with a 2.25 inch system. Just as a point of interest  Dave Vizard wrote that gains can be made by port matching the top and sides of stock exhaust (leaving the bottom of the pipe untouched so that a reversion dam is created in the pipe).  Not planning to take the time to do this.
Would love to go to headers and a more optimal performance transverse exhaust, but I live in California.  Summit and other vendors will not sell to California unless the parts meet C.A.R.B (air resources board) requirements.  Exhaust parts are only sold  with a C.A.R.B number.  If you know of a set of headers that Summit et alii sell to California for a 69 Camaro, let me know please.
Ace
X33RS
« Reply #13 on: February 23, 2019, 03:11:10 PM »
Not trying to sell you on it, but with your cam change and head work it does seem that you are at least a little performance oriented.  In which case I'd be looking at the 2 1/2" mandrel kits.  But I'm one that likes to make them run as well as they look without sacrificing the stock appearances, so I'm a little bias.
     My tests have all been done through the stock manifolds as well.  There is a lot to be found with just the exhaust pipe upgrades with these cars.  I talk to a lot of the PS guys, which is what my Formula as well as my Z was built to conform with.  Rules allow a maximum of a 2 1/2" system as one of the few areas an upgrade is allowed, but they all run stock exhaust manifolds per rules.  Most will tell you, no matter what the car or engine, that the exhaust pipes are one of the single most improvements made on their cars, and my testing has shown that as well.   Matter of fact, a lot of engine dyno testing has shown that the biggest improvement in the systems are the down pipes right off the manifolds.  That first bend off the manifolds is the most critical.  Going from a crush bend down pipe to a mandrel bend down pipe, and no exhaust system afterwards on an engine dyno, has shown as much as a 12hp difference alone on some engines.
  Crazy to think about, but thought I'd share.
    I went with the stock tail pipes on my Z because I do want to have a stock outward appearance, as that's really all you see, the rest of the system can't even be seen unless you're crawling on the ground.   But by all means, go with a reproduction system if you're looking for concours appearances and not that worried about performance.  It would certainly be an easier system to bolt on and function perfectly fine.
crossboss
« Reply #14 on: February 23, 2019, 04:22:09 PM »
Ace
Ace,
I used to live in LA as recent as last year and never had an issue with Summit selling me parts. CARB compliant parts are only for 'pollution controlled' years. Kinda doubt 1960's cars are associated with all that non-sense, and are exempt anyways. Emission tests are only for 1976 and newer vehicles. You can always say 'its for off road use only'. So, that said I don't know why Summit is refusing a sale.
Anyways, finding a set of headers for a Camaro with a small block is not gonna be difficult. Im sure some members on here have a set that they can sell you. Also try ebay and craigslist.
1968 Olds 442 W-30
