Author Topic: 68 TH400 dipstick 3905449  (Read 5229 times)
SS396
« on: February 14, 2019, 01:11:41 PM »
I had to purchase a dipstick for my TH400 due to the original one being damaged. Managed to track down a used one and would just like to verify that the length is correct as the zig zag area is a little distorted. When measured from inside the cap where it bottoms on the filler tube to the tip is 24 ¼”. Is this correct?
Re: 68 TH400 dipstick 3905449
« Reply #1 on: February 14, 2019, 01:34:36 PM »
 If this is the same for a 67 TH400 then I can take it out of my car and measure it.
Camarocards
« Reply #2 on: February 15, 2019, 01:05:25 AM »
Here area few pictures of my '68 "born with" TH400 dipstick. Note that it does not have a part number stamped on it but it does have the "M" stamp. I found this link which seems to indicate that yours may be a '69 dipstick??
https://www.yenko.net/forum/archive/index.php/t-98819.html
The overall length on my dipstick is 23 1/2 inches.
If you need more info just let me know.
Bob
Bob
'68 SS L35 01D
SS396
« Reply #3 on: February 17, 2019, 01:31:17 PM »
I read the article from your link Bob and the last post on there says mine is correct for 68 - 73 models with TH400. I'm not fussed either way. The only thing I was worried about is that it wasn't stretched or compressed from its original length.
« Reply #4 on: February 17, 2019, 01:37:24 PM »
I wonder what was different between 67 & 68 TH400 stick assemblies
big iron
« Reply #5 on: April 13, 2019, 11:12:13 PM »
Trans. oil pan and filter was changed for 68.
Bob
« Reply #6 on: April 14, 2019, 08:26:54 PM »
Bob
Our 69 L78 Nova TH400 dipstick has same script as what Bob showed (no part #) and measured basically 24 1/4".
