Author Topic: 69 Z28 Leaf Springs.  (Read 13018 times)
onekidbill
« on: February 13, 2019, 11:53:57 PM »
Hi ,
First time on the Forum,
I have a 69 Z28 that I've owned since 1976 and I'm in the process of putting the motor and a few other stock items back in the car. I'm from BC Canada and have GM of Canada Doc. on the car so I know its a true Z.My question is that will reading on the CRG site I came onto an article about the rear Leaf springs that there should be 4 and my car has 5. Can someone tell me if this possible as I know the rear end was changed but the springs came stock on this car.
Bill
69 Camero Z/28
68 Camero Z/28
68 Camero RS
69 Corvette 350/350  2010 Camaro 2SS
BillG
Re: 69 Z28 Leaf Springs.
« Reply #1 on: February 14, 2019, 12:00:03 AM »
4 leaf springs were part of the z28 option as you probably know.  Mabey when the rear was changed, the springs were changed along with it?
Bill Garrett
onekidbill
« Reply #2 on: February 14, 2019, 12:05:08 AM »
Thanks Bill
I have a orignal 68 z28 and it only has 4 so maybe it was changed.
69 Camero Z/28
68 Camero Z/28
68 Camero RS
« Reply #3 on: February 14, 2019, 01:06:21 AM »
Don't toss them too quickly! From the 1969 CAMARO VISUAL ID HYPERTABLE (Note 10):
Quote
Generally, Z28's used 4-leaf springs and the other multi-leaf spring applications used 5-leaf springs. However, the use of 4-leaf springs was not limited to just 68-69 Z28's. Spring selection was a function of weight and options - and this was fine-tuned in 1969. SS, LM1, L65, and COPO cars with 4-leaf springs are possible according to factory documentation and they have been observed on original SS, LM1, and L65 cars.
Factory documentation indicates that all 68-69 Z28's should have 4-leaf springs. One Z28 (a 69) has been found with apparently original 5-leaf springs. The 5-leaf spring usage on a Z28 should not be considered normative and CRG continues research whether 5-leaf springs were factory installed on the Z28.
Since that was written, we now have 6 1969 Z28's in the database with 5 leaf springs. Again, this isn't "normal", and we continue to research this, but we would LOVE to have data on your car.
You stated that the rear axle's been changed. What's the code stamped on the passenger side axle tube? This "might" help to confirm if the springs originally came on that particular axle.
« Last Edit: February 14, 2019, 01:29:19 AM by bertfam »
x77-69z28
« Reply #4 on: February 14, 2019, 03:16:42 AM »
My car had a helper spring installed at some point prior to me purchasing the car in 1978, with 32,000 miles on it.
jdv69z
  • 69 RS Z/28 52E
« Reply #5 on: February 14, 2019, 08:14:15 PM »
So when counting the number springs, do you count the lowest one which sits directly on the spring perch? It is much shorter than the others. Is that a spring, or just for mounting?
Jimmy V.
« Reply #6 on: February 14, 2019, 08:30:40 PM »
Quote
See attached.
onekidbill
« Reply #7 on: February 14, 2019, 11:34:28 PM »
Hi Ed
Here are some pics
69 Camero Z/28
68 Camero Z/28
68 Camero RS
onekidbill
« Reply #8 on: February 14, 2019, 11:36:09 PM »
69 Camero Z/28
68 Camero Z/28
68 Camero RS
« Reply #9 on: February 15, 2019, 12:48:45 AM »
Hard to tell from the pictures (too small), it appears those "might" be originals. Can you post a higher resolution shot of the clamps and the ends of one of the leafs?
« Reply #10 on: February 15, 2019, 01:35:22 PM »
Bill was the whole rear end housing swapped out? What gear is in it now?
jdv69z
  • 69 RS Z/28 52E
« Reply #11 on: February 15, 2019, 01:59:51 PM »
Thanks Ed, couldn't be much clearer than those pics. So my 69 Z has 5 springs, but it doesn't mean anything because I have a receipt from a previous owner showing that they were replaced. I'm guessing they were changed from 4 to 5 leafs at that point? Although the stance of my car seems to look to be the same as other Z's. Could be that the 5 leaf springs had the same effective spring rate as the original 4 leaf I guess.
Jimmy V.
« Reply #12 on: February 15, 2019, 05:21:45 PM »
 With the factory multi-leafs.....was the main spring a dual taper (width and thickness) like the mono leaf, or was it a continuous width along its entire length (I assume the thickness was tapered).
Just curious.
onekidbill
« Reply #13 on: February 15, 2019, 07:06:31 PM »
Hi Ed'
When I restored the car back in 82, I installed a 12 bolt posi with an original set of 3:37 gears out 69 Z. But the springs were never changed.I'll get the numbers off the housing and let you know.
69 Camero Z/28
68 Camero Z/28
68 Camero RS
onekidbill
« Reply #14 on: February 15, 2019, 07:08:16 PM »
More pice
69 Camero Z/28
68 Camero Z/28
68 Camero RS
