Author Topic: history of the rear spoiler on z/28 Camaros  (Read 3645 times)
pjbizjak
« on: February 08, 2019, 01:54:50 AM »
Can someone give me some history on the z/28 rear spoiler? Factory option? dealer option?
Re: history of the rear spoiler on z/28 Camaros
« Reply #1 on: February 08, 2019, 02:40:45 AM »
Start HERE and HERE, but also do a search on spoilers from Jon Mello.
« Reply #2 on: February 09, 2019, 12:38:32 AM »
Despite the photos of the prototype '67 Z/28 with a rear spoiler, it was never a '67 option.
Spoilers [front and rear] became an option [D80] during the '68 model year. There were two front designs used for '68. The early version [at least through April '68] fastened to the lower grille panel and did not use support brackets. The 2nd design was larger and used three mounting brackets.
D80 continued as an option into the '69 model year. All '69s built with D80 through early February used the narrower '68 rear spoiler. At that time some D80 cars received the wider '69 version. By March, all D80 builds used the '69 style. Early April '69, D80 was included with the Z/28 option.
There was no dealer option per se. But many Camaros had a rear spoiler added from the parts department. In production, one of the trunk lid torsion bars is stiffer to compensate for the added weight.
« Reply #3 on: February 09, 2019, 02:07:32 AM »
One of the torsion bars is thicker and thus stiffer.  On a Camaro that was produced on the assembly line without a factory installed rear spoiler (and the vast majority did not have one), both trunk lid torsion bars will be the same diameter.
« Reply #4 on: February 09, 2019, 01:42:39 PM »
Another difference for dealer installed is Camaro by Chevrolet emblem as in most cases a dealer would go to the extent the factory did in 68.
