Author Topic: Upper control arm bolt paint?  (Read 3194 times)
Tinkerr
« on: February 05, 2019, 04:04:58 PM »
I did a search and from the one picture I found, it appears the bolts attaching the upper control arm to the subframe are not painted. Is that correct? I'm going to paint it in a couple hours try to cover last minute issues. Thanks
Re: Upper control arm bolt paint?
« Reply #1 on: February 05, 2019, 04:36:08 PM »
 If you mean the ones that had the alignment shims then no, it wasn't painted. Only the shaft with the end caps/bolts were painted when the whole arm assembly was painted as a unit.
Tinkerr
« Reply #2 on: February 05, 2019, 04:39:59 PM »
That's what I was looking for.
Thank you Paul
m22mike
« Reply #3 on: February 05, 2019, 11:15:14 PM »
X2
