Author Topic: How to tell the date code and if these trim rings and centers are original  (Read 5278 times)
Emo1956
Hi Again , I need more help. Can you please tell me if these trim rings and centers look like the original type. I have a 68 SS with Disc . The rims are 14x6 and the bs is 3 7/8 code XG. I see what looks like K-1-9  is that like Nov 1 69 ???  Thank you Emo
Quote
I see no pictures but XG is correct for 1968 and 1969 with disc brakes and rally wheels. The date code of K19 is (K) Kelsey-Hayes, (1) Romulus, MI plant, (9) 1969. There should also be two more numbers on each side of the valve stem hole. Those indicate the month and day the wheels were assembled.
Emo1956
Sorry I forgot the pics !! Is this what happens when you get old ??lol
Emo1956
Pics
Ok, you're looking at 12-18 so December 18th, 1969 (XG rims were also used on the 1970 Nova), but the trim rings aren't correct, and the caps are 1967 only.
« Last Edit: January 31, 2019, 09:20:30 PM by bertfam »
dannystarr
Are those trim rings era correct? I always thought that style was a service replacement?... Danny
Emo1956
Thank you Ed. What am I looking for . My car is a 68 SS 396/375 02D Nor car.
Quote
Yep, you're right Danny. I wasn't thinking! I've fixed it.
dannystarr
Even a blind pig finds an acorn once in a while  ;)  ... I'll take it... Danny
Not sure but would assume correct wheels for your car would have large font and no date around valve stem, just the whl code in large font. Inside portion of rim month and year bot not seen with tire mounted. Date coding or much of it started mostly after your car was built. The trim rings as mentioned are much later service replacements.
VINCE Z28
Emo there is 2 XN wheels with rings and center caps for sale on Portland, Oregon CL for 100.00 you might want to check out. Vince
Emo1956
Thank you Vince. So what your saying I might as well just go buy new rims because no one can see it anyway. I already bought E-70-14 redlines when it was suppose to be F-70-14. I'll just buy new rims. Thanks everyone.
