I was doing some research on my spacesaver, and came across this thread while comparing my inflator and wheel. The 69 camaro AIM N-65 A1 shows two part numbers for the inflator assembly, 9793469 and also 9793470 beside which it has RPO L34 L35 L46 L48 L78 PW7 and PW8. So both inflator cans are correct for the 69. I believe the difference can be seen on the label itself which identifies the tire size, where 9793469 is for the 7.35 X 14 tire...and the 9793470 is for the 7.75 x 14 tire.
I have an HI space saver with a 7.35 x 14 tire, which I sadly have discovered with this research is incorrect for my L48. And the canister is part 486506 for an E78 X 14, which I don't understand and I don't find it in the AIM.
Thanks - Andy
