Author Topic: 69 camaro  (Read 14058 times)
GS STAGE 1
69 camaro
« on: November 26, 2005, 02:35:59 PM »
69 camaro
« Last Edit: December 04, 2005, 11:39:49 PM by GS STAGE 1 »
shift1313
Re: Buick nut needs help with newly purchased 69 camaro
« Reply #1 on: November 26, 2005, 10:50:00 PM »
well the axle casting date is november 22, 1968.  The date on your fisher body tag, 11D, is the 4th week in november.  That puts them close and the axle is before the body.  Id say as long as your vin ends in around 20000 the numbers side of things looks good.  but i looked back through the model ID pages and the only 327 listed says export on it.  Was the 327 not offered in 69?
matt
« Reply #2 on: November 27, 2005, 01:00:53 AM »
With the axle date of Dec 7 (casting date is not relevant to this question), it's too late for that car. Really close, but not close enough. :)
What's the VIN and the engine and trans codes?
There's also likely to be a broadcast sheet on top of the gas tank........
Thanks!
« Reply #3 on: November 27, 2005, 03:37:16 AM »
No, this is an early car. Nov of 68. Still had another month left of 327 production.
Yup, FL is the correct code.
Pretty unusual to find the broadcast sheet inside the car. Congrats!
Thanks!
Kurt
Mark
« Reply #4 on: November 27, 2005, 01:41:16 PM »
That's not your build sheet.  The body number on the build sheet looks to be 172050, your trim tag says 172093.  It probably belongs to a car made at the same time as yours, or perhaps was attached to an interior peice destined for that car that ended up in yours.
Can you read the VIN number in the third boxon the first row?  Looks like it ends in 354, is that your VIN number?
« Last Edit: November 27, 2005, 01:43:23 PM by Mark »
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Mark
« Reply #5 on: November 27, 2005, 03:38:12 PM »
Still have a crappy camera  ;)(at least looking at that image on my monitor).  I take it the number on the build sheet really is 172093 and does match your cowl tag.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Mark
« Reply #6 on: November 27, 2005, 10:00:53 PM »
And you got this for the $250 it says on the for sale sign?  The cars in better shape than my Pacecar was when I bought it int 83 and I still paid more for mine way back then.  good deal.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
4myz
« Reply #7 on: November 30, 2005, 03:50:25 PM »
Hello buick guy would you be interested in selling that rear end if so please contact me asap at(  herzogt@gmail.com )thanks
« Last Edit: November 30, 2005, 04:17:23 PM by 4myz »
