Author Topic: Kind of cool wonder if its real  (Read 9901 times)
ggtsvnv
« on: December 27, 2018, 04:40:58 AM »
https://lasvegas.craigslist.org/cto/d/albuquerque-camaro-28/6780399127.html
  Seems kind of cool, would take some money to make it right but you don't see them like this much anymore.
Re: Kind of cool wonder if its real
« Reply #1 on: December 27, 2018, 05:12:05 AM »
He says he has the build sheet, but no photo of it?  in fact, no photos of *anything* which might help to verify...
Too highly priced for what he's advertising - non original engine, no proof of anything else..  but if someone is close enough to check it out it's might be a good idea..
jdv69z
  • 69 RS Z/28 52E
« Reply #2 on: December 27, 2018, 01:50:09 PM »
So based on the the crumpled header panel, grille was replaced with a black one? (shouldn't it be silver?) And emblem left off? Build sheet would more likely be a LOS car? Spoiler added? What is that shifter? Never seen one like that?
Jimmy V.
X33RS
« Reply #3 on: December 27, 2018, 01:59:04 PM »
Worth investigating further.  I've seen rollers out here that were legit Z's, exchange hands for north of $25k so if it's real his price probably isn't that far out of the ball park.  If it's spent it's life out here it's most likely a very solid example to start with.
x66 714
« Reply #4 on: December 27, 2018, 02:02:01 PM »
Kind of looks like a super shifter but shorter. By the looks of the boot & carpet, I'll bet there's a huge hole....Joe
ggtsvnv
« Reply #5 on: December 27, 2018, 03:56:26 PM »
Most I see are either total hulks or restored dont see too many with the day two look to it. Used to see a lot of them like that in the late 70s and 80s. Would be neat to see the build sheet/broadcast sheet.
Hans L
« Reply #6 on: December 30, 2018, 01:35:35 AM »
Appears to have a front Endura Bumper, but missing the bumper guards in the rear....
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
« Reply #7 on: December 30, 2018, 05:40:18 PM »
He emailed me a pic of the broadcast copy. I can make out the code for the shocks to be PS which I thought was the correct front shock code for a Z. I can also see a pulley code of CG, which also looks correct. I forwarded the email to Gary, he can resize it better than I can.
« Reply #8 on: December 30, 2018, 08:11:28 PM »
Here are the two copies of the Broadcast Sheet which Austin sent me, reduced in size to fit our requirements...  I made no attempt to clean it up or make it more legible.   YF front springs, E70-15 tires, all legible indications are that the sheet came with a Z28...  I read the color as '65' which should be Olympic Gold?   Cortez Silver would be 69.  Does anyone have the VIN of the car to check with the sheet?
« Reply #9 on: December 30, 2018, 09:39:11 PM »
Looks good. Thanks Gary.
« Reply #10 on: December 30, 2018, 09:49:43 PM »
Bullitt,
Do you have the VIN of the car to verify against the broadcast sheet?/
BillOhio
    • photobucket
« Reply #11 on: December 31, 2018, 01:31:19 AM »
I thought G code on engine was for a Z. My fender extensions had GM on them
1968 RS 327 4 speed
« Reply #12 on: December 31, 2018, 02:36:35 AM »
Gary, I'll see if I can get a pic of it.
Hans L
« Reply #13 on: December 31, 2018, 02:45:09 AM »
He sent me a pic of the trim tag as well as the build sheet - I can upload later, but here's the details:
12437    VN
711    65 65
02B     1035
So appears it's been repainted.  Olympic Gold originally.
'70 Camaro SS L78
Hans L
« Reply #14 on: December 31, 2018, 02:48:52 AM »
And assuming the Build Sheet is from the car, has E70 15's....CZ Alternator, YF Rear Springs....65 65 paint code.   All seems like a legit LA built Z.
'70 Camaro SS L78
