Author Topic: Body Mount Tape - Width  (Read 59720 times)
Edgemontvillage
Re: Body Mount Tape - Width
« Reply #120 on: June 26, 2020, 01:14:17 PM »
Although there aren't many surviving examples of original tape to evidence the exact details of the factory practice of sealing the rear shock plate mounting holes and cutout prior to the water penetration test, I concluded rightly or wrongly that based on what evidence does exist and examples of tape used elsewhere on our cars for the water test (sub frame mounts) and for other, sundry applications (fuel sender and interior console), its likely the tape would have been a crepe style. I decided that 4 - 4 1/2" long and 2" wide was needed in order to cover the bolt mounting hole and cutout, mostly due to the awkward angles, so I cut a piece to size then, after applying sealer (dum-dum) around the bottom of the shock plate, bolted it in.
Crepe tape applied over rear shock plate holes.
Sealer applied to the back of the shock plate prior to installation (I actually used about 1/2 as much as is shown in the photo)
Restored Shock plate installed (followed by the original bumpers)
« Last Edit: June 26, 2020, 02:05:27 PM by Edgemontvillage »
« Reply #121 on: June 29, 2020, 12:41:43 PM »
As long as we were talking about the attachment of the subframe and under body... anyone notice the flat spring steel push clip?
Most people leave these off because they either do not know about them or laziness in sourcing them the use of the flat "speednut" or push clip makes installing the rad support a  near effortless operation for one person.
Above Bushing was sourced from CHQ - They are the correct size although there are no markings on the sleeved bushings, I can't rememeber whether some of the GM marked bushings came from Rick's or if they were ones I had collected, I know that the later replacement rad support bushing is not the correct diameter, and the reproductions one typically sees are also not the correct diameter.
x66 714
« Reply #122 on: June 29, 2020, 02:33:38 PM »
I can't seem to find CRQ, Camaro Head Quarters. Do you have a link to them?...Joe
« Reply #123 on: June 29, 2020, 05:06:28 PM »
CHQ is Classic Headqurters, and often offer the better parts than other repro companies. http://www.classichq.com/
x66 714
« Reply #124 on: June 29, 2020, 08:17:55 PM »
Thank you...Joe
bowtie68iho
« Reply #125 on: November 13, 2020, 01:04:29 PM »
I have more info that might help this older post on the correct width of the original body mount sealing tape used on the assembly line to seal #3 body mounts and rear shocks for leak testing.
I just obtained a copy of the GM Maintenance Products & Standard Stock Catalog 907 (P&A 24) dated March 1970.  Attached, is a photo of the sealing tape listed on page 11 in the Body Service Items section.  It appears that GM sold only two widths of sealing tape as service items, in both cloth and paper material: 1 inch and 2-1/2 inch.  Because GM most likely wouldn't waste money having a different width sealing tape on the assembly line than what they sold over the counter, we can probably assume that the service tape was identical to the factory assembly line tape.  Based on the anecdotal evidence of the various postings on this topic, along with photos of surviving black paper tape portions greater than 1 inch in width in both dimensions, one can probably conclude that the tape used for the leak test body sealing was #5786759, a black paper back tape, 2-1/2 inches wide.
Bernie
68 NOR SS/RS L48/M35 Convertible
Cordovan Maroon - Special Paint Exterior (black stripes)
Black Custom Interior
Silver Concours (Legends Class) at 2012 Camaro Nationals, Gold Concours at 2014 MCACN.
« Reply #126 on: November 13, 2020, 02:48:27 PM »
 Great info, Bernie!
 In checking that P/N in GM's Wiki, that usage goes back to the late 50's. Here is one example (it is shown as 'special service') http://www.gmpartswiki.com/getpage?pageid=8056
 I'm sure it shrinks over time which is why survivors seem to measure 2 1/4" thereabouts, especially with constant wetting and drying over the years.
  I agree with your conclusion about it being the same as production line usage.
« Reply #127 on: April 21, 2021, 07:51:15 PM »
Nice original with the good shots of the tap. https://www.ebay.com/itm/203361980412
