Author Topic: 69 DZ302 Vacuum Advance B28  (Read 5424 times)
Ken Maisano
« on: December 22, 2018, 06:06:36 AM »
Any idea were I can get one of these? All the crossover numbers also say they have been discontinued.
Kenny
Re: 69 DZ302 Vacuum Advance B28
« Reply #1 on: December 22, 2018, 03:48:07 PM »
Rock Auto has them. Do a search on DV1810. Auto Zone also carries them.
« Reply #2 on: December 22, 2018, 04:25:33 PM »
GM still had them as of a few years ago...
« Reply #3 on: December 22, 2018, 05:01:38 PM »
Quote
They still do. The Chevrolet part number is 1973469 (AC Delco P/N D1390A)
« Reply #4 on: December 22, 2018, 05:25:09 PM »
Related question:    Do any of you have a good 'home remedy' test for a vacuum advance unit (off the car)?   I've got a newly built '60 Corvette engine I'm trying to get going and I'm questioning right now if the vacuum advance is working correctly, but not sure how to test it...??
« Reply #5 on: December 22, 2018, 06:02:14 PM »
Suck into it and if it's bad, it won't hold the vacuum.
« Reply #6 on: December 22, 2018, 07:53:17 PM »
You could use a mighty Vac Brake bleeder tool to adapt to the advance?
I will try to dig mine out an see.
JIM
JKZ27
« Reply #7 on: December 23, 2018, 02:02:01 PM »
JIM
That's right Jim, use a hand held vacuum pump. Should pull the arm in and hold vacuum.
John
68 RS Ash/Ivy Gold 327EFI M20
« Reply #8 on: December 23, 2018, 03:37:55 PM »
Or you can save yourself a few bucks and do it the way I said in my reply #5!
JKZ27
« Reply #9 on: December 23, 2018, 04:24:02 PM »
Honestly, thats exactly what I would do first, Ed.  :)
John
« Reply #10 on: December 23, 2018, 04:35:11 PM »
What Ed said to do really does work! No cost.
« Reply #11 on: December 23, 2018, 08:02:36 PM »
basically all the responses suggested 'pulling a vacuum' by 'sucking on it'... Personally I like the idea of using a mechanical device (rather than my mouth) .. :) ..  to suck on it!  :)
So basically you fellas are saying that if the vacuum can is still sealed, then the degree of vacuum advance should be correct?  Or is there some simple means to checking the degree of advance off the engine?
« Reply #12 on: December 23, 2018, 09:16:23 PM »
that's correct. It either holds the vacuum or it doesn't. There's no "in-between".
Unless it's an aftermarket adjustable vacuum advance, it'll start pulling at whatever the spec is for that particular can. There's a small tolerance, but nothing worth mentioning.
