Author Topic: Big Block interior heater box question  (Read 3918 times)
x44d80
« on: December 16, 2018, 12:00:39 AM »
I am going to look at a 1st gen eater box I believe is from a. Big Block car.  I have read somewhere the frame that holds the  core is slightly bigger
than  a small block  box.  Can anyone confirm or deny this?  Thank you in advance.
Re: Big Block interior heater box question
« Reply #1 on: December 16, 2018, 12:55:48 AM »
 To my knowledge the inside housing ( AIM UPC 1/A6 heater & defroster assembly) is the same for BB & SB, just the heater core and retainer is different, plus the large rubber gasket (covered SB tube exit from firewall). The outer heater cover is very different though and it brings the hoses out the middle.
« Reply #2 on: December 16, 2018, 03:17:56 AM »
True. The bb inner has a larger mounting area for the heater core.
« Reply #3 on: December 17, 2018, 01:16:33 PM »
http://www.camaros.org/forum/index.php?topic=15852.msg142630#msg142630
The exterior dimensions of a non ac BB & SB interior side of the heater box is identical. The same goes for the outer, as well. The inner box is the same, save except the outer vertical heater core panel. It is moved to the right 1/4 inch making the heater core area dimension wider. If time allows, I will get a measurement of both, bbc & sbc/6, inner box widths.
x44d80
« Reply #4 on: December 30, 2018, 06:23:20 PM »
Thanks for the replies.  One other small difference on the Big Block box are the dimples on the sealing area by the mounting studs.
