A retired GM Engineer that was directly involved in the mid to late 60's tells me
the original "intent" was to see how much if any HorsePower some of the then available
aftermarket "CrossRam" Intake(s) for Big Block Chevy would make...
They started with one that had 2 Individual plenums and it did NOT work well due to pulses...
So in doing development at GM by a GM Engineer on a Chevrolet Big Block with a Crossram
it was found the larger the common plenum area the better, ending up with a large single plenum
but with the horizontal tuned length individual runners on the floor of the plenum...
Having tuned length intake runners was key for power... and
a single large common plenum to "manage" the pulses without disturbing carburetor fuel air distribution.
-BUT- no "desired" application was identified for use on the Big Block Chevy...
Can Am "went" all Injection to achieve tuned runner length and required no plenum, not carburetion...
So... the "learnings" and "development" done by GM Engineering on the Big Block Chevy
for an under-hood tuned length runner common plenum carburetion Intake manifold was "re-applied"
for the Small Block 302 Camaro Z-28 Trans Am Racing CrossRam, where there was an "application".
There may have been aftermarket Big Block Chevrolet CrossRam Intakes produced,
but in testing done by GM Engineering none were found to be actual "functional" power producers...
