Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Mild Modifications
zz502 into 69
« previous
next »
Print
Pages: [
1
Author
Topic: zz502 into 69 (Read 8122 times)
69aus
Newbie
zz502 into 69
on:
February 26, 2007, 04:41:16 AM »
Anyone done this transplant? Does the 502 sump fit and is there any other clearance problems when fitting to 69. Also are there any headers that will fit without adjustment ? Are the smallblock engine mounts ok ?
Thanks in advance
Tweet
Logged
sdkar
Hero Member
Re: zz502 into 69
Reply #1 on:
March 14, 2007, 01:19:54 AM »
You can use either hooker headers (part # 2457) or if you have some extra money, go to Dougs headers (
http://dougsheaders.com/tv/
) for the 502 to fit in the 69 Camaro. You will definitely need to change the oil pan to a 4 quart pan to clear the crossmember. There is an oil pan offered that is specifically made for the 502 in a 69 Camaro. Other than that, everything will fit fine.
Logged
sdkar
Hero Member
Re: zz502 into 69
Reply #2 on:
March 18, 2007, 03:51:43 AM »
Here's what you need.
http://cgi.ebay.com/ebaymotors/GM-Performance-Parts-4-Quart-Oil-Pan_W0QQitemZ200089823315QQcategoryZ140690QQcmdZViewItem
Logged
Print
Pages: [
1
« previous
next »
Mild Modifications
zz502 into 69
