Author Topic: Need Ball Joint Rivets Installed  (Read 15392 times)
Tinkerr
« on: December 05, 2018, 10:54:21 PM »
Looking for someplace to install my upper ball joint rivets. I live in Frederick, Md, can travel to Virginia or Pennsylvania. I called around today, 6 different restoration shops including Corvette restorers and all said they don't do them. One fellow only does them on his customers restorations, just use bolts is what I was told. Alot of Restoration Shops doing "Complete,Total,Full Frame Off Restorations", apparently all those descriptive words have different meanings.
Camarocards
Re: Need Ball Joint Rivets Installed
« Reply #1 on: December 05, 2018, 11:17:12 PM »
I had mine done by Bair’s Corvette. They did a fabulous job. Here’s a link to a thread on the Team Camaro website which talks about the ball joint rivets:
https://www.camaros.net/forums/16-brakes-suspension-steering/456777-upper-control-arm-rivet-problem.html
Bob
Bob
'68 SS L35 01D
Tinkerr
« Reply #2 on: December 05, 2018, 11:42:58 PM »
I'll contact them tomorrow. I'll have to ship to them, they're 5 hours away. Anybody have anything closer to the DC metro area. Thanks
JKZ27
« Reply #3 on: December 08, 2018, 02:19:51 PM »
Anyone tried doing these rivets themselves? I'd be tempted.
John
68 RS Ash/Ivy Gold 327EFI M20
« Reply #4 on: December 08, 2018, 04:38:09 PM »
I tried to "TOOL" up to perform this task and failed -
Challenges, Sourcing quality correctly size starting stock rivets, Correct Tooling for "Backing bar" & "Buck"  driver for proper setting of rivets, Making a stable set up to crush aka set rivets,  was a big pain for just 6 pc of hardware, I went with ZIP products threaded rivets the Vette houses sell and called it good.
JIM
Kelley W King
« Reply #5 on: December 08, 2018, 04:50:38 PM »
Are the replacement A arms that have the ball joints and bushings installed junk or incorrect? I saw one of the magazines put them on a 70 Chevelle. Looked like a correct part.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #6 on: December 08, 2018, 11:54:00 PM »
As Bob mentioned Bair's (Western PA) is a good choice and even though they are a Corvette house they do our A-arms as well. Another choice is contact Ken Lucas at Lucas Restorations as he has a source that does a great work and he's in MD.
http://lucas-restorations.com/
Tinkerr
« Reply #7 on: December 09, 2018, 04:40:07 AM »
I'm going to ship them to Bair's when they come back from the powdercoater, $25 per-side plus shipping. That seems reasonable and they have a good reputation. I'm having second thoughts about the powdercoating though. It seems from my reading, the control arms were fully assembled, painted then the ball joint was installed. If that's the correct sequence my cross shaft bushing won't be painted. Were the bushings installed before painting?
Edgemontvillage
« Reply #8 on: December 13, 2018, 12:14:24 AM »
The control arm, dog bone (control arm shaft), washers, bushing retainer bolts and bushings should all be painted (30% gloss) once the control arm is assembled if you are seeking a factory correct look. The assembly was actually dip painted prior to installation of the ball joint by the original supplier however that's rarely seen and not very practical or cosmetic. Powder coating is also a good choice for durability. Good idea to go with rivets rather than bolts for the new ball joints - happens to be one of my pet peeves, rivets just look right on our cars.
« Reply #9 on: December 13, 2018, 12:47:51 AM »
There is nothing wrong or inferior with modern paint technology compared to powder coating. What do non-professionals think their brand new car is painted with? I have had to repair powder coated parts which was  no picnic. Powder coating can be stained and softened by solvents.  It also comes off with lacquer thinner. Urethanes are not affected by thinners; professional painters know this. I've painted frames and suspension parts decades ago that are not failing. Some of these cars are driven daily, washed, and driven in the rain. Scary experience for some.
They sell hardware for ball joints that have rivet heads which are secured by a nut if 100% accuracy is not a concern.
« Last Edit: December 13, 2018, 01:30:30 AM by Sauron327 »
« Reply #10 on: December 24, 2018, 10:56:20 PM »
The correctly finished A'arms above have the incorrect bushings.
They should have a 3/16 exposed rubber lip on the inside.
Edgemontvillage
« Reply #11 on: December 29, 2018, 03:28:42 AM »
James, I have seen them with and without the bushing exposed inboard, what source are you referencing that states there is only one correct version?
Hans L
« Reply #12 on: December 31, 2018, 12:59:55 AM »
Lloyd -
Here's the original upper ball joints that I had removed from the upper A-Arms.  '69 04B LA Build.   They were riveted in, so no reason to believe they were not original.   Only wish I would have just cleaned them up and left them in place.
Hope this helps.
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
« Reply #13 on: December 31, 2018, 05:56:02 AM »
When I rebuilt my front suspension (~65K miles), the upper BJ was good so I simply cleaned them in place.  Here are photos showing the Ball joint and rivets from top and bottom sides.
« Reply #14 on: December 31, 2018, 08:26:24 AM »
The ball joints were not in question...
They are the correct Stepped version which I have seen on nearly all 69 model and newer GM's. The bubble top version was not used after early 69 as far as I can tell.
The original HARRIS dogbone bushings have an inner edge which has 3/16-1/4" exposed rubber lip on the inside of the bushing. The correct appearing bushing is reproduced albeit without the HARRIS name (the name is not visible installed however the exposed rubber lip is visible.
pay no attention to the wire in the foreground... look at the bushing with the exposed rubber.
