Author Topic: Stove Pipe Question  (Read 4091 times)
69 ice cat 8
Stove Pipe Question
« on: December 05, 2018, 10:31:32 PM »
Hello Members,
 Does anyone know is a stove pipe heat riser from a 6 cylinder '68 Camaro will fit a 327-210 hp '68 Camaro?
Thanks in advance.
Re: Stove Pipe Question
« Reply #1 on: December 06, 2018, 12:37:39 AM »
I moved your thread from the Site Comments section, but I believe the answer is no. The 6 banger pipe (P/N 3915952) is longer and shaped differently than the LF7 pipe (P/N 3917680).
« Reply #2 on: December 06, 2018, 12:51:17 AM »
Do you need one for a 327? Send me a pm.
« Reply #3 on: December 06, 2018, 01:09:22 AM »
Bryon, also note there's a difference between the LF7 pipe (P/N 3917680) and the L30/L48 pipe (P/N 3916309).
« Reply #4 on: December 06, 2018, 01:49:08 AM »
Hard to tell Bryon.
HERE'S ONE ON EBAY to compare.
« Reply #5 on: December 06, 2018, 02:29:30 AM »
Not sure if this one is for a 1968 base 327 or not. Might be L30 and L48 with automatic trans.
« Last Edit: December 06, 2018, 04:03:33 AM by bcmiller »
« Reply #6 on: December 06, 2018, 03:08:42 PM »
I don't think yours is the LF7 Bryon. I think yours is the L30/L48 version as you suspect. Here's what the LF7 looks like (see attached). Notice that the end that attaches to the air cleaner doesn't bend up as much as yours.
