Author Topic: front grill color 68 z/28 camaro  (Read 4577 times)
pjbizjak
« on: November 18, 2018, 10:05:27 PM »
OK guys, I bought a new unfinished grill for my 68 z/28 and want to know what color to paint it?
Z10Mike
Re: front grill color 68 z/28 camaro
« Reply #1 on: November 18, 2018, 11:06:49 PM »
I think that grille should be silver as with a standard Camaro.  At least that is the color scheme on the 69's.
« Reply #2 on: November 18, 2018, 11:17:33 PM »
Look up Chick's 68 Z thread.  He shows the correct color and yes the inner portion of the grille is silver but the outer portion is satin black.
« Reply #3 on: November 19, 2018, 12:45:39 AM »
Would this work?
Plastic Prep: SEM 39863 Plastic Adhesion Promoter Aerosol - 14.8 oz
Semi gloss black surround: SEM 39143 Trim Black Aerosol - 15 oz.: Touchup Paint
ARGENT Silver Center: Krylon metallic paint dull aluminum k01403007
Chicks thread indicates they use a "GRAY" not disclose formula as a base prep?
Did you purchase a repop grill, can you comment on fit and finish?
JIM
« Reply #4 on: November 22, 2018, 02:36:54 AM »
Here’s a survivor grille to assist with the black paint line.
This is an original 68 grille and note the plastic color is a tan or cream looking color. If you look back close to the first picture you can see that tan/cream color at some of the horizontal bars as the paint did not fully cover all areas. I would call the painted grille color more of a mix between silver and gray. Note the rivet heads for the bracket that was riveted to each end of the grille. I might or should have the formula of what we color matched if needed.
This was our NOS grille and note this 1983 (date on box) service replacement was a dark gray.
After painting it with a color matched paint to match originals!
After riveting brackets to grille!
Grille as we were installing!
