Author Topic: CRG Report on Fan Blades question  (Read 11455 times)
1967butternut
    • MemphisGuru.com
Re: CRG Report on Fan Blades question
« Reply #15 on: April 09, 2020, 10:06:10 PM »
I've got two very similar four blade fans trying to figure out which is correct for LOS Feb 67 build, 327 2bbl LF7 (No A.I.R.) base V8 model.
No part numbers stamped into 4 blade fans?
Damon
My 1967 Z21 Pictorial History
The Memphis Guru, a web guy you can talk to.
www.MemphisGuru.com
« Reply #16 on: April 10, 2020, 03:16:29 AM »
Most fans don't have part numbers stamped in them....
1967butternut
    • MemphisGuru.com
« Reply #17 on: April 10, 2020, 04:49:29 PM »
Thanks, good to know.  Makes it a lot harder to tell if a particular fan is really the correct one for a particular car.
Of course any of the four blade fans will be closer to original than the fiberglass flex fan that's been on my car for at least 45 years!
Damon
www.MemphisGuru.com
« Reply #18 on: April 10, 2020, 05:58:04 PM »
Neither of my '67 fixed blade fans have numbers. I believe one has the letter 'S' stamped in the hub. Maybe the mfg?
1967butternut
    • MemphisGuru.com
« Reply #19 on: April 10, 2020, 07:09:22 PM »
I don't see any stamps at all on mine. Do you have one that no doubt came from an original 1967 V8?
Does your look like one of mine?
I noticed that one of mine felt heavier than the other, so after weighing and measuring found that
The darker one in the pictures is 8 ounces heavier and has 1/2 inch longer blades tip-to-tip.
Lighter one: 1 lb. 15.2 oz, 17 1/8 inch long blades.
Darker one: 2 lb. 7.2 oz, 17 5/8 inch long blades.
Could someone weigh and measure a fan that is for sure an original part?
Damon
www.MemphisGuru.com
