Author Topic: 69 Tilt Wheel Whats it worth?  (Read 12179 times)
02undercover
« on: February 24, 2007, 12:39:01 AM »
I have a chance to buy a tilt column out of a 69 Z28 with the key. What is it worth?  Thanks
KevinW
Re: 69 Tilt Wheel Whats it worth?
« Reply #1 on: February 24, 2007, 01:27:42 PM »
$200-$450 depending on condition and completeness.  I costs around $250 to have them rebuilt.
Jonesy
  • 1969 Camaro z28
« Reply #2 on: February 24, 2007, 02:36:52 PM »
Thats one piece that hasnt gone up in price like the price of most other parts.
1969 Z28 Azure Turquoise
cfar
  • L30/M35 Tuxedo Black
« Reply #3 on: February 24, 2007, 05:05:35 PM »
give it time and it will go up in value-supply and demand always control the market.
11C 1967 - Born on date estimated Nov 15th,1967 LA Plant
In Service Jan 18th, 1968  Hollywood CA
« Reply #4 on: February 24, 2007, 06:27:31 PM »
Careful here. There are several swap meet pirates selling made-over tilt columns as '69s.
Virtually dozens of GM tilt columns made well into the '70s were the same length and will physically fit a '69. The main difference is the locking lever at the base of the column; '69 seems to be a one-year only style and if the column is not a '69 you will end up having to make it work. Also be sure to get the flange that adapts the column to the rag joint. The standard '69 column has an integral flange welded to the lower shaft; tilts have a splined shaft for a separate flange.
02undercover
« Reply #5 on: February 24, 2007, 10:08:18 PM »
I do know this column . It was taken out of the Z in 1975. The car was hit in the rear. Still have the finders , doors, wiring, some gages, and the title.  The car was huger orange.       Thanks.
Bjv69ss
« Reply #6 on: February 26, 2007, 12:01:09 PM »
A rebuilt tilt column with the correct flange costs $310.00 from "Ricks First Generation".  I wouldn't pay much more than half that even if it does have the tumbler and key.  A new lock set for the doors and the column is only $29.95 from Ricks and they will match.
Joe
1969 Fathom Green
SS 350 Coupe
71 Impala Sport Coupe
mvara71
« Reply #7 on: February 26, 2007, 09:25:47 PM »
My tilt steering came from a 67 or 68 firebird it cost me 50.00 dollars `cause I had to remove it myself, and I did had to change the locking lever I use the one from my original column.
