Author Topic: REAR LEAF SPRINGS PAINT  (Read 5223 times)
Franko
« on: September 27, 2018, 12:48:52 AM »
I'm going to paint my 1968 Camaro's rear leaf springs. Were the rear leaf springs unpainted from the factory? If so, I was thinking of using Cast Blast (cast iron looking paint) because I've had good results with it on a master cylinder and exhaust manifolds on a different car.
Re: REAR LEAF SPRINGS PAINT
« Reply #1 on: September 27, 2018, 02:20:09 AM »
 They were painted a sort of gray/blue primer. This link has a good thread on it. I bought the paint and have to agree that is is real close.
http://www.camaros.org/forum/index.php?topic=10112.msg77644#msg77644
Pacecar
« Reply #2 on: September 27, 2018, 05:59:05 PM »
The rear springs weren't painted. They were a tempered metal finish, so yes they will look a bluish gray. Best way i have found is to use gun bluing to replicate the original finish. the retention brackets and plastic spacers are available new
« Reply #3 on: September 27, 2018, 09:14:44 PM »
I have removed flakes of paint off preserved areas under the perch rubber
This is for mono springs. Maybe multi-leafs are different.
« Reply #4 on: September 28, 2018, 12:06:57 PM »
Monos are painted grey, multis are natural spring steel color. A 67 I did had the original gray under the perch as Mike stated. Take a ride to your local spring shop to see actual multi appearance.
x77-69z28
« Reply #5 on: September 28, 2018, 08:26:44 PM »
My 67 had gray paint under the perches when I disassembled it
Buddy
sixt9x33rs
« Reply #6 on: October 17, 2018, 01:57:36 AM »
I have had good luck preserving mine with Boeshield after I had them re arched. The color the Boeshield leaves on them is close to the right color.
« Reply #7 on: October 20, 2018, 12:21:16 AM »
Buddy
The 67's look like the tranverse leaf springs in corvettes.
