Author Topic: 1969 LM1 could this be one  (Read 22819 times)
camaromikey
« on: February 22, 2007, 04:42:22 AM »
I have a 1969 camaro. Its VIN is 124379n56057. I've decoded its cowl tag. It was LeMans Blue with ivory standard interior and a parcemnt vinal top. It built in the second week of december.  It still has the orignnal rear end which a 12 bolt with a 2:56 ring gear and multi-leaf springs. Im guessing it was a 350 v-8 car because it has the duel fuel lines and it was a small block car. It was 3 speed auto with colume shift. It had four wheel non power drum brakes.  I just wanted to know is there a way to find out if it was one of these cars. I don't have a build sheet but everything I have points that way. Any help
cfar
  • L30/M35 Tuxedo Black
Re: 1969 LM1 could this be one
« Reply #1 on: February 22, 2007, 04:58:06 AM »
Post the cowl tag numbers and that may help ID the car better and the rear numbers if you have them.
11C 1967 - Born on date estimated Nov 15th,1967 LA Plant
In Service Jan 18th, 1968  Hollywood CA
camaromikey
« Reply #2 on: February 22, 2007, 05:06:21 AM »
the tag reads: st6912437nor195236bdy
                    tr727  12b  71e  pnt
                             x44
« Reply #3 on: February 22, 2007, 07:27:03 AM »
Yes, the car is an LM1. No other model could have an X44 tag and 2 fuel lines.
Could you check the VIN, it's missing a digit?
Do you have the rear axle code?
Thanks!
camaromikey
« Reply #4 on: February 22, 2007, 05:26:03 PM »
sorry the vin is 124379n560573. i will post the rear axles codes later today. has this car ever been registered?
click
    • Our 69 RS
« Reply #5 on: February 22, 2007, 05:37:06 PM »
Kurt Im surprised that he found a 2:56 gearing in that 12bolt. Although I suppose someone could have changed out the gears. With the LM1 were you able to order such a highway gear for it? I thought only the Powerglides had that low of an option?
« Reply #6 on: February 23, 2007, 04:12:57 AM »
I've seen others with a 2.56. It appears that it was the economy ratio.
No, it was not in the database.
It has a 3 speed indicator on the column? Trans is gone?
Thanks!
camaromikey
« Reply #7 on: February 23, 2007, 05:22:29 PM »
Yes and the orignnal engine. It has a 75 350 in it now, but Im building a 327 for it out of another 69 camaro. It will take few days for me to get the axles codes. What can i do to get it registered.
« Reply #8 on: February 25, 2007, 06:39:39 AM »
It's already added to the db. :)
camaromikey
« Reply #9 on: March 13, 2007, 06:59:26 PM »
i got two of the rear axle numbers. i have the casting code which reads L68. i looked at the chart on CRG that was just posted but mine has only those 2 numbers and that letter. Also I have casting number which is 3894860NF which i already know its a 12 bolt. Thrusday I'll post the axle code because i have to pull the tires off. I know it starts with a P
huggerorange
« Reply #10 on: March 14, 2007, 06:57:38 PM »
Congratulations. It sounds like a really cool car. I have heard of LM1s, but what exactly were they?
Don from Midland, TX
« Reply #11 on: March 14, 2007, 08:47:57 PM »
Don -
Here's your answer:
http://www.camaros.org/lm1.shtml
camaromikey
« Reply #12 on: March 15, 2007, 03:15:13 AM »
Its going to be a really cool car some day. It's just a daily drive for now. It needs to be restored but Im doing what I can till that time comes. It was my first car so its really specail to me
camaromikey
« Reply #13 on: March 16, 2007, 04:15:14 AM »
the axles code is PY1101G now it also had a marking behind the G that looked like another 1, but im not sure if thats part of the number. So is it possible for it to be the right rear end.
« Reply #14 on: March 16, 2007, 04:48:53 AM »
camaromikey -
Yes, it appears to be the correct rear axle for your car.  Yes, the 1 after the G is part of the axle code and is interpreted as "first shift".  PY1101G1 decodes as 2.56:1 axle ratio, non-posi, 12 bolt rear axle assembled on November 1, 1968 by the Detroit Gear & Axle Plant, first shift.  The date also would be correct for a 12B built car.  Congratulations!
