Hello again. I own this particular car and have plenty of 1st gen knowledge, but not as much as the expert people on this forum. I concluded right away when i looked at the trim tag that it did not belong on this particular Camaro. The ONLY option that matchex up is that it is a convertible car. I bought it in a package deal with another 67 Camaro RS/SS 350 rag top car with good options. The car in question is mostly a parts car. The VIN does not match up to the other two locations and i believe it is installed backwards. Viewing with door open it is inverted 180, but it does have the rosette rivets. Probably glued or panel welded in. Car is in bad shape with one repaint since plates swapped and has multi colored body panels now. Any trim tag info, aside from it's valuable options, would be greatly appreciated. I am trying to decide what to do with the car.
Thanks, Shawn
