Author Topic: rebuilt engin startup  (Read 7918 times)
pjbizjak
« on: September 05, 2018, 11:03:57 PM »
Hi all, Planning to fire up my fresh rebuilt 302 in a few days(have other things to do first) and I would like some feedback on how long to let it run, what rpm etc. I will prime the oil pump first, pan filled with royal purple 5w30, topped off with amsoil assembly lube. Set the valves @ 24 cold, it's has the comp cam 30/30 grind. heard both settings 24 & 30 lash? Using super hi test gas. Engine put together with original 68 crank, pink rods, J&E pistons new valves & sprins basically upgrading the 302. block bored to 40 over was 30 over before. I'll try and answer any questions.
Thanks Pete
jcihos
Re: rebuilt engin startup
« Reply #1 on: September 06, 2018, 12:05:43 AM »
When my 383 was broken in we stayed between 1500-3000 rpm for around 30 minutes if I remember correctly. Then we allowed it time to cool down. My engine builder put in Joe Gibbs Driven break in oil at a 20w50 for break in then I was able to switch to VR1 10w30. Total run time for my engine on the dyno that day was about 4 hours while we dialed in timing, jet sizes etc.
BillOhio
    • photobucket
« Reply #2 on: September 06, 2018, 12:58:19 AM »
5w30- seems pretty thin??
1968 RS 327 4 speed
Kelley W King
« Reply #3 on: September 06, 2018, 11:40:09 AM »
Your cam instructions will dictate the first half hour. After that if it is in the car I vary RPMs for awhile watching all the vitals. They say new ring materials don,t really need to "seat" but I still see a little blow by for a while.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Stingr69
« Reply #4 on: September 06, 2018, 12:46:38 PM »
Dont forget water in the cooling system and a fire extinguisher.  The GM Engine Break-In Oil Additive is the best.  If you have factory stamped steel rocker arms you want to run the tighter lash spec.  If you are using aftermarket rockers you can set them at the looser spec. The tighter spec was based off of the factory pieces.
If you want to be persnickety you can set the valves just zero lash at .020" LOBE lift (not at valve, measured at pushrod top travel) to lash aftermarket (or any other ratio) rockers with a GM spec 30-30 cam.  You need a dial indicator for this.  The GM spec lobes have a .020" slow lift portion of the ramp where all valve lash is taken up.  That is the exact point where all the lash is removed when the lash is set perfectly.  Snug the lash at the valve to zero while at .020" LOBE LIFT, rotate the cam way off the ramp (it is LONG) and measure the clearance at the valve. Use that measurement at the valve for setting all the valves with any rocker arm and a GM 30-30 cam.
rodent
« Reply #5 on: September 08, 2018, 06:39:00 PM »
If you're running dual or triple valve springs, pull the inners out and reinstall after run in.
« Reply #6 on: September 08, 2018, 07:10:00 PM »
ONLY Water no coolant please learn from my 1985 Emergency room visit to the "Mary Bridge" Tacoma General Burn center stay. (1967 Camaro 454 Upper Catastrophic Rad Hose failure) Thank goodness only Water my burns could have been much worse.
Stay safe.
JIM
RS Copo
« Reply #7 on: September 12, 2018, 10:11:33 PM »
Is that RP oil synthetic? It's generally not recommended to use synthetic on break in.
rodent
« Reply #8 on: September 23, 2018, 07:36:54 AM »
How did you get on with the startup?
rodent
« Reply #9 on: November 27, 2018, 08:08:47 AM »
Crickets........
crossboss
  • ^ New engine project
« Reply #10 on: November 27, 2018, 02:23:12 PM »
Thanks Pete
Id recommend you use conventional oil (at least 30W), and some zinc additive especially with a flat tappet (non-roller) cam. Prime it before you fire it up is preferred. Run it with water only, and for at least 20 minutes @ 2,200 RPMs.
1968 Olds 442 W-30
