I have the assembly manual and two small instructional booklets, one is for 1967 Camaro wiring and the other is specifically for RS HL wiring and it has a trouble shooting guide but regarding this, simply says a switch is bad. But I'd be happy to read anything pertaining to this type of issue so please forward or tell me where to find.
It worked, and then stopped and its both sides on the same motion. Heck of a coincidence.
I physically engaged the limits switches and it did not stop the "cycling".
Rick67, I had found that link in my earlier searches and those pics were very helpful on initial assembly! I was amazed at how easily everything fell into place. I looked up the trouble shooting chart and it says:
"Double bounce is usually caused by slop in the door bushings or slop in the drive washers. This will not damage the Retro Electro motors." Everything is brand new, bushings, bolts, etc ... the doors are nice and snug and have no extra play. The actuating arms also have no play. I moved everything manually during set up to ensure everything was aligned properly and all four switches were engaging, and it worked perfectly ... once.
