Author Topic: '67 Starter Solenoid WIring Harness Retainer?  (Read 5723 times)
Buzz67
« on: August 19, 2018, 04:46:11 AM »
Hello Members,
Can anyone tell me if '67 L35 starters had these starter solenoid wiring harness retainers? HBC lists this as a 67 part, but it's not in the AIM. Was this perhaps added later as a service bulletin item or wasn't it used in '67?
http://www.heartbeatcitycamaro.com/store/product/13263/67-68-69-70-71-72-Camaro-Starter-Solenoid-Wiring-Harness-Retainer-GM%23-3906181/
Buzz
'67 RS/SS L35, M40, Red/Red Coupe, NOR
Original Drivetrain w/3.73 posi
Original Rally Wheels, Manual Disc, Steering
3rd Owner
Re: '67 Starter Solenoid WIring Harness Retainer?
« Reply #1 on: August 19, 2018, 06:40:55 AM »
Buzz, you need to check out UPC 12, Sheet A9, Item number 6 in the AIM. P/N 3906181 Clip.
Buzz67
« Reply #2 on: August 19, 2018, 07:33:18 AM »
Hi Ed!
It looks like I ALSO need to work on my usage of the AIM! I was only looking on the L35, Sheet A5 and expecting that to tell the whole story. WHOOPS!! Lesson Learned.
Thanks for setting me straight,
Buzz
3rd Owner
luv2sixty9
« Reply #3 on: August 25, 2018, 10:52:12 PM »
The one Heartbeat is offering is for 68 69 Model year. The 67 is different in appearance....... Dave
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
« Reply #4 on: August 26, 2018, 12:08:06 AM »
 That sure looks like the one in the 67 AIM UPC12/A9.
What is different, Dave?
luv2sixty9
« Reply #5 on: September 09, 2018, 05:19:42 PM »
67 Doesn't have the upper loom and or smaller hook on top.
1969 RS SS Pace Car
Buzz67
« Reply #6 on: September 11, 2018, 12:33:55 PM »
Shoot. I already purchased and installed the Heartbeat version. Anyone know of a source for the '67 retainer? I'm still working on that side of the car and it's very accessible right now.
3rd Owner
« Reply #7 on: September 11, 2018, 12:49:59 PM »
I'm not so convinced you have the wrong clip, Buzz. After researching this more I see the clip change from p/n 3856490 to 3906181 as per AIM 12/A9. The revision date is 10-7-66 but the transition can be afterwards.  The 3856490 clip, without the 'loop', was the type used on Corvettes. I can see why it had no loop being the design of the Corvette exhaust manifold. With the Camaro's log type design the loop wouldn't hit it nor prevent it from being removed. The AIM clearly shows the loop (and yes I do know the AIM isn't 100% correct all the time).
  But, if you want to locate a source just in case you can get it at places like ZIP Corvette here:
https://www.zip-corvette.com/66-67-427-68-82-starter-solenoid-cable-clip.html?gclid=Cj0KCQjwz93cBRCrARIsAEFbWshUeDOFEOtl8uwMSQ2CTuwzfgJjXRzp1wfQdv3Nbr5xpfZWW7PGDb4aAt42EALw_wcB
Buzz67
« Reply #8 on: September 11, 2018, 07:38:55 PM »
I believe I'll wait to see if a judge gigs the one I have. Then I'll buy the other,.....maybe! But thanks guys for educating me! I just love learning about 1st gen Camaros!
3rd Owner
