Author Topic: Holley 4053  (Read 7635 times)
rlw68
Holley 4053
« on: July 27, 2018, 12:26:36 PM »
Does this appear to be the real deal or a re-stamp ?
Rob
1969 02D Norwood Z/28. Lemans Blue 715
Re: Holley 4053
« Reply #1 on: July 27, 2018, 02:05:49 PM »
IT looks good...
Re: Holley 4053
« Reply #2 on: July 27, 2018, 08:01:04 PM »
But you have to see the rest of the carb to know if it has the correct parts on it.  I have a 68 4053 but it has a restamped metering block on it that some seller put on it and took the original.  The only way I found out is when it was being restored and it didn't look right to the guy doing it.
rlw68
Re: Holley 4053
« Reply #3 on: July 28, 2018, 12:22:38 AM »
Front and rear pics below.
Rob
rlw68
Re: Holley 4053
« Reply #4 on: July 28, 2018, 12:31:50 AM »
Metering block is 4519 ?
Rob
Re: Holley 4053
« Reply #5 on: July 30, 2018, 01:15:39 AM »
It has the correct base plate as well...
The correct base plates without the LUMP on the drivers side rear mounting hole/rear throttle shaft boss are not reproduced.
That's a really nice carb. Is it for another car of yours?
rlw68
Re: Holley 4053
« Reply #6 on: July 31, 2018, 12:19:25 PM »
Thanks for the info!  Yes this was for another but I didn't get it.   Winning bid on eBay was $440.
Rob
Re: Holley 4053
« Reply #7 on: July 31, 2018, 12:39:09 PM »
Rob I was watching it, it's relisted with start bid of $425.....
Opium Motors
Re: Holley 4053
« Reply #8 on: August 01, 2018, 05:32:40 AM »
That part no. will work on a late 68 or early 69 Camaro
68-69 302
68 396
Hope that helps
1968 Camaro RS Convertible 327 4 Speed Corvette Bronze
1973 Corvette 454
Re: Holley 4053
« Reply #9 on: August 01, 2018, 01:26:30 PM »
Quote
While it will work, it's not factory correct for a 68 or an early 69. The date is 934 which is the 4th week of March, 1969. Too late for an early 69 and way too late for a 68.
jdv69z
  • 69 RS Z/28 52E
Re: Holley 4053
« Reply #10 on: August 01, 2018, 02:09:39 PM »
My early 69 Z's (10B) carb is actually from Jul of 68, 872.
Jimmy V.
Re: Holley 4053
« Reply #11 on: August 01, 2018, 03:43:02 PM »
Quote
That's because they were built in batches. My 05D L89 has an 833 (third week of March, 1968) assembly date.
