Author Topic: Measurement Tools  (Read 8647 times)
Kelley W King
Measurement Tools
« on: July 05, 2018, 11:28:00 AM »
Has anyone tried the calipers from Harbor Freight? I would use one very little but the price is right. I would just use it for general things, not engine clearances or things like that. I have their temp laser and it works great and one of the magazine tests rated it very well. Just trying to do better than a cresent wrench and steel ruler.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Re: Measurement Tools
« Reply #1 on: July 05, 2018, 11:56:10 AM »
It will be fine. Buy it.
Kelley W King
« Reply #2 on: July 05, 2018, 12:02:56 PM »
Thanks Bentley. Trying to measure some pins on my 69 SS Dover white backhoe.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
« Reply #3 on: July 05, 2018, 01:48:55 PM »
As bad a critic as I am about Chinese sourced tools, they'll work for what you need them to do. I bought a digital micrometer from my local store (in a pinch to accurately measure drill diameters down to the micron), and they worked as I hoped they would. Amazing results for $35.00 - but I still prefer a good Starrett or B&S if I can find a pre-owned one.
Stingr69
« Reply #4 on: July 05, 2018, 05:43:33 PM »
I have one and use it a lot.  No regrets. It is not digital, just old school with mechanical dial.
Have a dial indicator and magnetic base from them too.  Good for degreeing cams and such.
« Reply #5 on: July 06, 2018, 03:16:40 AM »
Steve,  I trust you don't really believe the tool  you purchased is accurate to 1 micron???   :)     There are 25.4 microns in 1/1000 of an inch...  :)
ie.  1 micron would be 0.00004"
« Reply #6 on: July 07, 2018, 03:04:31 AM »
Gary,
Tolerance on these particular drills is an .008mm total h6 or k6 class, h6 is + 0.00/-.008mm (minus tolerance), k6 is +0.001/=0.009mm (plus tolerance). Target drill diameters are usually 3.968mm or 3.920mm h6 or k6. Yep, my company can grind them to these tolerances, and hold them. I get inspection reports with every order, unless one gets mis-placed (which is why I had to check them). It's a little tedious, but you get the hang of finding the high points of the margins after a bit. Don't get me wrong, a laser mic is way more reliable than me checking by hand -
m22mike
« Reply #7 on: August 08, 2018, 12:39:42 AM »
There are lots of good used ones on eBay , starret or brown and sharp for a couple .
JMO
« Reply #8 on: August 08, 2018, 02:24:56 AM »
I have two of the cheap digital calipers that I take to swap meets (they work good) - and one good set of Starrett micrometers for very fine measuring.
« Reply #9 on: August 08, 2018, 03:32:45 AM »
I sold Starrett, Brown and Sharpe, Mitutoyo, Fowler and others for years, I can remember the first digital caliper I ever saw (believe it was a B&S), cost was unreal. Now you can buy the cheap versions for $15.00 on sale, and they work for what you need them to do. Break 'em or lose 'em, go buy another.
Mike's right, surf eBay and pick up the great older tools for a fraction of what they sold for, and treasure them. Use the cheap ones for field work -
« Reply #10 on: August 08, 2018, 04:04:47 AM »
Steve, which brand or brands were usually the best?
« Reply #11 on: August 09, 2018, 12:12:29 AM »
People were usually split, depending on what they were exposed to early on. Both Starrett and B&S were first choice for most toolmakers and tool and die guys, maybe leaning towards B&S in the earlier days for me. I remember being horrified to see "Made in Japan" on Mitutoyo tools when they were first introduced (to me), but the quality sold a lot of people on the line.
Boiled down to personal preference -
