Author Topic: OIL LINE FITTING  (Read 4846 times)
ALLZS
OIL LINE FITTING
« on: June 30, 2018, 12:59:22 PM »
what does a original oil line fitting that screws into the block on a 69 Camaro  smallblock with factory gauges look like
Re: OIL LINE FITTING
« Reply #1 on: June 30, 2018, 01:06:20 PM »
Several good threads here with pictures, use the 'advanced search' function.
Couple of examples:
http://www.camaros.org/forum/index.php?topic=11720.0;all
http://www.camaros.org/forum/index.php?topic=11068.0;all
262jp
« Reply #2 on: June 30, 2018, 02:54:15 PM »
I make these up to what I believe is the correct configuration. Pm if you need one.
« Reply #3 on: June 30, 2018, 11:07:36 PM »
Maybe you could post a picture to see what you believe to be the correct configuration.
What many use is this and it meets all judging requirements that I'm aware of.
http://www.heartbeatcitycamaro.com/store/product/25755/1967-1968-1969-Camaro-Console-Gauge-Oil-Line-Fitting-OE-Style-Correct-GM%23-3904227/
262jp
« Reply #4 on: July 01, 2018, 02:21:26 PM »
Appearance wise the one you list from HBC is correct, but the ferrule and nut is not.
« Reply #5 on: July 01, 2018, 10:10:37 PM »
Correct ferrules and nuts are discussed and pictured in the (long) thread I linked to in the earlier reply.
262jp
« Reply #6 on: July 02, 2018, 01:54:48 AM »
Reply # 83 in the long post are the correct parts.
