Author Topic: How to Confirm ID of 1967 A/C Controls?  (Read 4487 times)
1967butternut
    • MemphisGuru.com
« on: June 16, 2018, 04:30:20 AM »
My 67 doesn't have A/C.
About 20 years ago I broke the defroster lever in my dash heater control, a common problem.
Back then they didn't make a replacement repop, and I ended up fixing it with a tiny piece of metal, a couple of screws, and good ole JB weld.
Before I did the repair I tried to buy a used replacement control set, but the seller sent me a set with A/C controls. I ended up keeping it thinking I might add A/C someday and it would be nice to have.
Now I'm looking at it and I can't figure out how to confirm that it is even from a Camaro, more less specifically a 1967 as advertised back then.
Can anyone tell me about it based on the pictures? I don't see anything that looks like a date code, is there one or am I missing it?
Full size photos are at https://www.linkpro.net/piwigo/index.php/category/6
Thanks for any info.
Damon
My 1967 Z21 Pictorial History
The Memphis Guru, a web guy you can talk to.
www.MemphisGuru.com
1967butternut
    • MemphisGuru.com
Re: How to Confirm ID of 1967 A/C Controls?
« Reply #1 on: June 16, 2018, 04:32:24 AM »
More pictures of numbers
Damon
www.MemphisGuru.com
1967butternut
    • MemphisGuru.com
« Reply #2 on: June 16, 2018, 04:33:24 AM »
and one more
Damon
www.MemphisGuru.com
« Reply #3 on: June 16, 2018, 01:59:00 PM »
That's a mid 68 control.
Below is the 67 (top picture), and very early 68 / mid 68 (bottom picture).
More info HERE.
« Reply #4 on: June 16, 2018, 02:33:03 PM »
I had some thoughts on this but nothing solid.
But I had a feeling that Ed would have answers for you.  :)
1967butternut
    • MemphisGuru.com
« Reply #5 on: June 16, 2018, 04:59:53 PM »
More info HERE.
Thanks Ed, So really these can be ID'd simply by looking at the face and there isn't anything significant about all the numbers inside. Good to know.
I have my original controls out of the car to replace the control cables and bezel, which is what got all this started.
I'm wondering if I should go ahead and replace the fan switch, do those go bad? I see they are available now.
You might get a kick out of my half-ass JB-Weld repair, that repair worked, but unfortunately I went a little crazy and epoxied the tabs that I broke getting the case apart.
Pictures https://www.linkpro.net/piwigo/index.php/category/7
Damon
www.MemphisGuru.com
