Author Topic: Heater hoses  (Read 24132 times)
RRMs69Z
Heater hoses
« on: June 11, 2018, 02:30:19 AM »
The AIM shows the lower hose crossing over the upper hose for a V8 engine. However, I see a lot of pictures that have a band around both hoses that attaches to the alternator. Which is the correct way to install the hoses?  Thanks.
Re: Heater hoses
« Reply #1 on: June 11, 2018, 12:41:37 PM »
Drawings are not gospel, pictures are
Re: Heater hoses
« Reply #2 on: June 13, 2018, 02:59:59 PM »
From my observations: The metal band attached to the alternator was used on the early cars, later cars did not use that band, and I have just seen the rubber ties.
Hopefully Kurt or someone may know when they stopped using that metal band.
Bentley (Ko-lec-tor) is correct, original pictures are best to go off of when you have them.
x66 714
Re: Heater hoses
« Reply #3 on: June 13, 2018, 03:13:36 PM »
The metal strap is on my 08E car but it's a 396 so that might be different. One hose comes from the water pump to the forward position & the other comes from the intake & it takes the rear position on the clamp (metal strap)...Joe
Hans L
Re: Heater hoses
« Reply #4 on: June 13, 2018, 03:17:42 PM »
Here's a picture back from 1990 of my Z/28 - it has the original heater hoses.   Note both metal clamps - on the alternator and on the inner fender.  04B Van Nuys Built.
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
Re: Heater hoses
« Reply #5 on: June 13, 2018, 05:10:21 PM »
Pretty sure all of them have the inner fender clamp, but the alternator clamps I have seen hold both hoses, and it appears in your pic to be holding only 1?
Hans L
Re: Heater hoses
« Reply #6 on: June 13, 2018, 05:25:01 PM »
Could be but it's a figure 8 style clip.  This the best pic I have so can't be sure.
'70 Camaro SS L78
Re: Heater hoses
« Reply #7 on: June 13, 2018, 06:14:43 PM »
Ok, now it makes me think you have the solenoid clip (bracket) bolted in there? Pretty sure that is in the wrong spot.
Hans L
Re: Heater hoses
« Reply #8 on: June 15, 2018, 03:56:00 AM »
OK.  Correction!  Found a better image - how's this?  Again, these are back from 1990.  Original heater hoses.  04B Van Nuys Built.
'70 Camaro SS L78
Re: Heater hoses
« Reply #9 on: June 15, 2018, 03:51:55 PM »
Hmm, that appears to be the right clip, but that also looks like a more recent picture?
I don't doubt your hoses could be original, but that clip could have been added anytime before the 90's.
I went through my pics from guys BITD or buying them new (1969), and I also have seen some unrestored cars. I have seen that bracket in your last pic on early cars, but then at some point it seems they stopped using it. Not sure if it was a big block only piece at that point, most of my pics are of small blocks.
Hans L
Re: Heater hoses
« Reply #10 on: June 15, 2018, 05:22:16 PM »
Yeah, I took the picture with a 35mm Camera back in the day and had it digitized.   I'm 99% confident the hoses are original.  70K miles on the car.  Correct "ribbing", clamps, etc.  I still have them.   The car still had the original power steering belts and many other original components.  Unfortunately, the prior owners put a smaller carb and headers on it.
'70 Camaro SS L78
Re: Heater hoses
« Reply #11 on: June 15, 2018, 06:47:24 PM »
Well the hoses look original. My only question is when did they do away with that bracket? and was it only in certain applications ?
RRMs69Z
Re: Heater hoses
« Reply #12 on: June 16, 2018, 02:20:20 AM »
Thanks guys. I would like to know if any one can confirm the picture in the AIM is the way it was done for cars built later in 69.
Re: Heater hoses
« Reply #13 on: June 16, 2018, 01:58:42 PM »
Knowing the build month and week of your car might help - to compare with another car. Things changed more than once during the model year.
X33RS
Re: Heater hoses
« Reply #14 on: June 16, 2018, 04:07:48 PM »
How much later in 69 are you looking for?
My 12D Norwood Z has the clamp on the alternator that holds both hoses, so what is seen in the AIM must be for cars after that date and maybe further.
