Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
69 inner lower quarter panel stamp
« previous
next »
Print
Pages: [
1
Author
Topic: 69 inner lower quarter panel stamp (Read 3581 times)
rlw68
Member
on:
June 08, 2018, 05:17:21 PM »
I found this sheet metal stamp on the LH inside lower rear quarter panel. It appears to be more than a date code. Maybe some kind of run number? This is on my 69, 02D build.
Tweet
Logged
Rob
1969 02D Norwood Z/28. Lemans Blue 715
Hero Member
caretaker of 1971 LT1's 11130 & 21783
Re: 69 inner lower quarter panel stamp
Reply #1 on:
June 11, 2018, 12:39:27 AM »
02D build Panel stamped the 8th week of the year... sounds perfect to me!
Logged
rlw68
Member
Reply #2 on:
June 14, 2018, 03:09:03 PM »
Thanks, yes that helps with the K08 part of the stamp and agrees with the limited info published by CRG
http://www.camaros.org/numbers.shtml#sheet
(details about the plant codes are not provided) I'll guess that K is Kalamazoo.
The L8753 after the K05 is what I found interesting. Its not part of the body number or vin.
Logged
Rob
Hero Member
Reply #3 on:
June 18, 2018, 10:33:40 PM »
That is most likely a die number, lot number, run number, version number, stamping plant id etc.
Logged
Print
Pages: [
1
« previous
next »
Decoding/Numbers
