Author Topic: How to disconnect/unplug engine & light harnesses from firewall block  (Read 4846 times)
77thor
Ok, I'm in the middle of a under-dash wiring harness replacement using American Autowire 'Factory Fit' harness...
How do you remove/unplug the lighting & engine harnesses from the firewall side of the fuse panel??
I removed the center bolt from the firewall side and also removed the 2 inside screws holding the fuse panel.
But I still can't budge them... Is it just 50 years of gunk holding them in? or did they apply some sealant at the factory?
I'm worried about prying on them and possibly breaking the connector.
Kelley W King
It is not gunk. They used some tar like sealer that works really well. Never tried it but a heat gun might help.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
77thor
The other problem is, the brake booster is in the way and I can barely get my hands on the connectors.
77thor
Got it.
It is easier to leave the two screws that hold the fuse box to the firewall in when unplugging.
