Author Topic: Rear Axle Brake Line Clip PN# 3956700  (Read 37878 times)
Edgemontvillage
Re: Rear Axle Brake Line Clip PN# 3956700
« Reply #45 on: June 26, 2018, 08:09:14 PM »
Hans, good question. As the car will be judged I don’t want to defend a seemingly “non-normative” part or worse take a points deduction and be informed of that deduction once judging results are received following the event with no ability to appeal (see Chick’s judging experience). In the Camaro hobby there are no judging guides/manuals so we rely on the knowlege of individual judges. To de-risk judging, where I have found non standard parts (or finishes etc) that I believe to be original (another example is the wheel well plugs) I have decided to replace them with the generally accepted standard part. Replacing the brake line clip is an example of that approach.
« Reply #46 on: July 02, 2018, 10:21:43 PM »
Lloyd, just noticed a BU rear listed on ebay, has a frame-mounting type of retainer clip in this location - similar to the one Rick (HOT302) posted back on page 1....... although it's not bolted up.
https://www.ebay.com/itm/Original-1969-Camaro-Z28-L78-BU-12-Bolt-Posi-Rear-End/202357847578
Edgemontvillage
« Reply #47 on: July 03, 2018, 04:43:19 PM »
Thanks Tim. For the sake of another data point I'm adding photos of the eBay listed diff. The seller ( BDCAMARO ) states "Original 1969 Camaro Z28 L78 BU 12 Bolt Posi Rear End All original as it came on the GM assembly line...with original dated GM 3:73 gears and Eaton position unit....". IMO the diff appears reasonably original except maybe the axle vent.
Edgemontvillage
« Reply #48 on: July 12, 2018, 02:18:22 PM »
Here is an original clip (now restored) that I located for my project:
Hans L
« Reply #49 on: July 12, 2018, 05:16:33 PM »
Nice!   What sort of finish did you apply to the clip?
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
Edgemontvillage
« Reply #50 on: July 13, 2018, 12:19:19 AM »
The clip was vapor blasted, so its unplated steel, then treated with rust preventative like Boeshield.
