Author Topic: 67 Camaro Rear Wheel Can Plugs  (Read 7217 times)
luv2sixty9
« on: June 02, 2018, 04:57:23 PM »
Would like to know what your 67 Camaro has originally installed from the factory;rubber or plastic plugs or a combination of both.
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
67CruiseMaster
Re: 67 Camaro Rear Wheel Can Plugs
« Reply #1 on: June 02, 2018, 05:24:06 PM »
What do you mean by wheel can plug
67 Tuxedo Black Convertible.
« Reply #2 on: June 02, 2018, 06:46:14 PM »
Right. I don’t understand the question.
WorkinProgress
« Reply #3 on: June 03, 2018, 01:08:15 AM »
Do you mean the plugs in the bottom of the rear wheel housing?
                                                       - Warren
luv2sixty9
« Reply #4 on: June 03, 2018, 12:50:02 PM »
Yes, the rear wheel housing.
1969 RS SS Pace Car
67CruiseMaster
« Reply #5 on: June 03, 2018, 06:56:41 PM »
Mine were plastic
luv2sixty9
« Reply #6 on: June 04, 2018, 02:47:29 PM »
1969 RS SS Pace Car
« Reply #7 on: June 04, 2018, 03:27:21 PM »
 Both my 67's have the plastic caps in the wheel wells and the rubber plug at the base of the panel that meets the rear lower quarter.
luv2sixty9
« Reply #8 on: June 05, 2018, 12:09:50 AM »
Mike,
Are you referring to the lower trunk drop that has the rubber plug.
1969 RS SS Pace Car
« Reply #9 on: June 05, 2018, 02:29:35 AM »
Correct....the trunk drop panel.
