Author Topic: 1969 Z/28 console temp gauge intermittent  (Read 2710 times)
ellis3071
« on: May 17, 2018, 05:56:04 AM »
Looking for tips on curing my console temp gauge on my 69 Z/28. Sometimes it works fine & other time it pins itself cold while the car is running. As soon as I shut the car off the needle moves to indicate the temperature. I have replaced the sending unit on the block for the correct console gauge restoration unit, traced the wire all the way & also replaced the low fuel module after seeing it was in bad shape. I'm temped now to replace the gauge itself. I have checked my grounds also.
Appreciate any suggestions !
1969 Z/28, original sheet metal numbers correct motor & drive line, fold down rear seat, vigalight, houndstooth interior.
Re: 1969 Z/28 console temp gauge intermittent
« Reply #1 on: October 07, 2019, 12:24:20 AM »
Really old thread but, I will add a few set up photos and results; Bench testing Console *68/69 U17 Amp meter, Water temp & Fuel level gauges. I experience similar pegging of the temp gage with my set up, was a intermittent console harness ground.
Pics to follow
JIM
