Author Topic: GM hood hinge springs  (Read 16601 times)
RAS68
« on: May 12, 2018, 12:34:36 AM »
This post is about my experience with hood hinge springs on my 68 SS. I know there are some older posts on this subject but I think this warrants a new post to share some part numbers. When I refreshed/restored my 68 SS in 2017 I thoroughly cleaned and painted my original hood hinges. I bought and installed new reproduction hood hinge springs for SS hood application. These were made by Classic Industries and had 28 coils. The hood always sagged a little. I thought it might be due to the somewhat worn original GM hinges. Recently, I decided to try GM hood hinge springs part number GM 3848272. The GM springs look pretty much identical to the reproduction springs. I installed the new GM springs and now the hood opens easier and there is no sag at all! I am very pleased. The GM springs are not much more than the repro SS hood hinge springs but they made a world of difference. I recommend using the GM springs that you can get from any GM parts dealer. Also, I used the washer trick to remove and replace the springs - that method works very well and its pretty easy. I hope someone finds this information useful.
Allen
'68 SS L34 07C NOR
Re: GM hood hinge springs
« Reply #1 on: May 12, 2018, 01:00:05 AM »
Didn't know they were still available from GM..... thanks!
BTW have you read the hood hinge spring info here?
« Reply #2 on: May 14, 2018, 12:48:11 AM »
I think another key point is many cars can use the original hood hinge springs as in many cases they are not pitted with rust. A good soaking in Evapo-rust and oiling or some other rust preventative is all that is needed in many cases. Our 68 utilizes the original springs and they look like new.
« Reply #3 on: May 14, 2018, 01:00:13 AM »
 I replaced the 67 hood springs with GM springs (28 coils) recently and they look and fit exactly as the originals.
The finish is an oiled phosphate. The originals would allow the hood to slowly close about 1/2 way.
67 nut
« Reply #4 on: September 06, 2018, 12:50:12 AM »
Mike,
(Don't want to steal this thread) Are those new GM springs in a zinc phosphate (silver), or in the manganese phosphate (dark gray)?
Steve  '67 RS convertible, factory a/c, parchment interior
Buzz67
« Reply #5 on: September 06, 2018, 01:08:23 AM »
I'll echo Chick's advice. That Evapo-rust stuff is a restorer's magic elixir! I soaked my rusted driveshaft inside a PVC tube of Evapo-rust overnight and it came out looing like new! And the painted stripes (not even visible before) hadn't been chemically removed and were now visible for documenting and repainting! Great Stuff!!
'67 RS/SS L35, M40, Red/Red Coupe, NOR
Original Drivetrain w/3.73 posi
Original Rally Wheels, Manual Disc, Steering
3rd Owner
« Reply #6 on: September 06, 2018, 03:06:39 AM »
Mike,
  They were covered in a thin oil when removed from the wrapper and the hue matched the hood hinges exactly. It's hard to tell what color but I would say dark gray. As I understand it, GM used phosphate on parts, which provides a good base for a followup oil treatment. This was a low cost method of rust control. Yes, phosphate a part and rinse and dry it and it is a tone of gray. But put an oil on it, which I believe the factory did, (I use Dri-Touch) and that gray changes. After it is on for years it will turn to a sort of olive green, like a firearm.
« Reply #7 on: September 06, 2018, 02:33:40 PM »
GM Part number?
« Reply #8 on: September 06, 2018, 03:17:50 PM »
Because the springs are spring steel, they have a different hue and value than the phosphated hinges.
« Reply #9 on: September 06, 2018, 05:19:11 PM »
GM Part number?
The GM P/N is 3848372 and I paid $30 for the pair.
It is a 28 coil spring. Attached is a picture of the spring in its packaged oil finish. It matches the hinge but in the photo it appears slightly darker.
« Reply #10 on: September 06, 2018, 06:02:30 PM »
« Reply #11 on: September 06, 2018, 11:36:53 PM »
GM Part number?
Please explain how metals manufactured with different  procedures produce the exact same hue and value in regard to springs and hinges.
« Reply #12 on: September 07, 2018, 12:01:05 AM »
Scott,
  What are you talking about?  The picture speaks for itself in regards to hue between the spring and hinge. Looking at it in person they look the same. The photo shows a slight variance.
Buzz67
« Reply #13 on: September 07, 2018, 11:46:36 PM »
I decided to have my hood springs phosphated right along with the hinges, hood release, lower pulley, just to keep the rust at bay. I knew it wasn't technically correct, but just wanted them protected from future rust.
3rd Owner
« Reply #14 on: September 08, 2018, 01:24:17 AM »
Scott,
Mike, I think Scott is referring to the difference in material with one being spring steel and other using a phosphate chemical finish. The spring steel has a smooth texture and looks like it is, spring steel. I understand your point as they do have a similar dark appearance but understand Scott's point as well. Here is what our 68 original hood springs looked like after some evapo-rust and protection but again, they had very little in the way of rust. And then one of our restored hood hinges with a spring attached. How close in darkness I think we can agree depends on the color/type of the phosphate/manganese used. Nice example shown Mike!
