Author Topic: 69 fuel line sleeve  (Read 7803 times)
Danzo
69 fuel line sleeve
« on: May 11, 2018, 12:36:39 AM »
Does anyone have a picture of an original 3908307 sleeve? Thanks.
Re: 69 fuel line sleeve
« Reply #1 on: May 11, 2018, 12:51:49 AM »
Sorry can you specify what model/year this sleeve is for and where it is located? posting a pic of the AIM may help us help you as well.
(many guys may not know the part number by heart) :)
Danzo
« Reply #2 on: May 11, 2018, 06:05:29 PM »
69 Z, on the gas tank supply line behind the strap.
« Reply #3 on: May 11, 2018, 06:46:44 PM »
GM parts book lists that number for 67-68.  But I suppose could also be 69.
« Reply #4 on: May 11, 2018, 07:54:48 PM »
It's on ALL cars.
For 1967 it's shown on UPC 8, Sheet B2, Item 6, for 1968 it's on UPC 8, Sheet B4, Item 6 and for 1969 it's shown on UPC 8, Sheet B5, Item 6. It keeps the fuel line from rubbing against the gas tank strap and basically looks like a 3 or 4 inch piece of foam rubber hose. It was also used on other models and other years as well.
Note that it was also used on the 67-69 convertible parking brake cable to keep it from rubbing against the X brace. (for 1967 and 1968, UPC 5, Sheet C1, item 3 and for 1969, UPC 5, Sheet C1, Item 8.)
HawkX66
« Reply #5 on: May 12, 2018, 06:56:07 PM »
There was one on my 69's original tank. 08D 69.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
Danzo
« Reply #6 on: May 12, 2018, 11:31:22 PM »
Dave,do you happen to have a picture of it?
Thanks.
KevinW
« Reply #7 on: May 13, 2018, 11:08:43 AM »
Hmm, when I did my gas tank replace, there were two anti rub "things" I could not find. The thick isolators on the mounting points and the center one. For the center one I used sheet neoprene foam (from McMaster-Carr) and cut it like original and contact cemented it to center of tank (to keep it from rubbing trunk floor).
For the mounting points, I took roofing felt and contact cemented 4 layers together to get the correct thickness.
My point is you have to get a little creative on some of these small parts if they are not reproduced :)
I would just take some 3/8" rubber fuel line, cut to length.  Then throw it in some boiling water to really loosen it up, then slide on sending unit tube to proper place, and wha-lla!
Danzo
« Reply #8 on: May 13, 2018, 01:36:15 PM »
Planning on doing that. Was just looking to find out what material the sleeve was made out of.
Thanks Kevin!
x66 714
« Reply #9 on: May 13, 2018, 05:32:17 PM »
It's 2-1/4" long, 3/4" diameter black foam rubber medium density with 3 external ribs. It's not split. Does that help?....Joe
Danzo
« Reply #10 on: May 13, 2018, 11:39:46 PM »
Joe, possible to post a picture or 2?
Thanks.
x66 714
« Reply #11 on: May 14, 2018, 12:40:31 AM »
Here you go....Joe
HawkX66
« Reply #12 on: May 14, 2018, 11:55:12 AM »
Thanks.
Sure. Here you go.
Dave
Semper Fi!
Danzo
« Reply #13 on: May 14, 2018, 11:13:27 PM »
Joe and Dave, thanks! Now to find some.
169INDY
« Reply #14 on: May 17, 2018, 10:49:58 AM »
04C LOS Z11 w/ measurements
JIM
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
