Update...
50 year old Holley 780 Vacuum Secondary
This problem just started out of the blue. Car was running great. Now does not start without starting fluid. And fuel leaks out of the secondary shaft on both sides ONLY after I turn the engine off.
Cut-in liquid filled Marshall fuel pressure gauge, gauge reads
5.5 at idle. So regulator has NOT failed.
Changed Needle and seat in both bowls
Tested both power valves, they are good. Installed with new gaskets.
Cleaned the metering blocks with carb cleaner and air
Power valves are 6.5, Vacuum at an idle is 11, Close enough for now, I can put 5.5’s in later. Needle stays VERY steady.
When I slowly rev the engine to 3K the vacuum jumps to 17, when I rack the throttle the vacuum drops to 7. I believe this is normal.
Float bowls fuel level at sight screw BARELY comes over the bottom of the female threads at an idle.
Secondary blades had NO slot clearance showing. I adjusted JUST so the opening was the sum of the width of the rectangular slot. The Primary blades have a Strong 1/8th of an inch showing.
Carb Rebuilder left out a ball bearing in the secondary’s, I remember seeing that pop out on me once. I put it back, as I didn’t even know it was there. THIS carb, does not have that ball. DO I NEED IT? WHAT IS IT?
While engine is running at idle, the inside of the carb is DRY! All blades are dry. When I turn the engine off, fuel begins to drop in from up at the squirters and cover the secondary blades… THEN drip out of the shaft on each side.
WHY do I always get these weird glitches in my carbs?? I am done for the day. Under a house the last two days for 11 hours total!! My back hurts
Danny
