OK, so after some research on this, I found the following specifications from the 1969 Chassis Service Manual for V8 Engine, non-transistor ignition:
Coil Primary Resistance: 1.77 to 2.05 ohms
Coil Secondary Resistance: 3,000 to 20,000 ohms
Primary resistance measured with multimeter between the coil +ve and -ve terminals.
Secondary resistance measured with multimeter between the high tension tower and either +ve or -ve terminal.
Secondary resistance range seems fairly broad, for example a reading of 3k ohms is within spec but would give a significantly different spark quality than a coil reading at the upper limit of 20k ohms.....
Anyway, thought I'd close out the question for future searches, time to check my coil now.
