Tim, this set appears cobbled together, the load rest appears correct and it has the usual stamping, the base is not nor is the jacking mechanism, both are incorrect. The photo doesn't show enough detail to assess the mast (although the trapezoid shape is typically correct). The shape of the jack handle looks OK however the photo detail is inadequate.
