On a 68 RS, is the side marker lamp wiring a separate pigtailed harness, plugging into the taillamp harness on each side, or is it one uninterrupted wiring loom direct to the side marker harness. I have two harnesses, basically identical to each other, which came with my basket case, neither one installed, (backup lamp plugs cut off)one harness ends on each side with a 2-prong plug, the other harness is straight through to the side markers.
Does anyone know which is correct fo 68? Is one possibly a 69?
68 - separate harness just for the side marker lamp?
Or 69?
Thank you
