Author Topic: Big block heater hose question!  (Read 6876 times)
hgger69
  • Hugger orange rules!
    • Håkans Motorsida
« on: April 05, 2018, 01:34:20 PM »
Hi,
I´m going to install the heater box hoses on my ZL-1 build but I´m not sure which one goes where?
The ASM shows this, which looks nice but is it correct?
I did some search on the net and found this thread that John Z commentated the same question with the opposite place for the hoses:
The hose from the outlet fitting (manifold) always goes to the bottom heater core fitting, and the hose from the inlet fitting (water pump) always goes to the top core fitting; that way the core is always full of coolant and there's no "gurgling" sounds from air bubbles audible from inside the car.
 The upper hose from the core back to the water pump is slightly larger in diameter so it always has lower pressure (carrying the same volume of coolant) to maintain steady coolant flow at low rpm so constant temperature control adjustments by the customer aren't required.
What du you original guys say about this topic?  ???
Hakan from Sweden
www.hakansmotorsida.com
Everett#2390
  • ^Bess
Re: Big block heater hose question!
« Reply #1 on: April 06, 2018, 12:02:22 AM »
Supply hose to core is 5/8 inch from intake manifold.
Return hose is 3/4 inch to water pump nipple.
hgger69
    • Håkans Motorsida
« Reply #2 on: April 06, 2018, 05:44:34 AM »
Thanx Everett, but this means that the ASM is completely wrong then?? :-[
Hakan from Sweden
« Reply #3 on: April 06, 2018, 12:24:36 PM »
Not the first time the assembly manual was wrong.
« Reply #4 on: April 06, 2018, 12:36:54 PM »
 I looked at my 67 L35 and the water pump hose attaches to the top pipe on the heater box and intake manifold to the bottom pipe. This matches the 67 AIM.
Being the heater box has two different size pipes and the engine has two different size nipples, just match the two.
hgger69
    • Håkans Motorsida
« Reply #5 on: April 06, 2018, 12:59:37 PM »
Great picture, thanks! :)
Hakan from Sweden
hgger69
    • Håkans Motorsida
« Reply #6 on: April 06, 2018, 01:03:18 PM »
The heater core does have two different sizes on the tubing but I don´t think there are two different sizes of the nipples on a 69 BBC but while I built my engine myself I could be wrong!  :P
The picture in my first post is from the 1969 ASM, or AIM, and apparently it´s wrong then!  ::)
Many thanks for your help in this matter, guys! :)
Hakan from Sweden
Kelley W King
« Reply #7 on: April 06, 2018, 05:05:33 PM »
Haken, I remember that picture of your pump to intake hose being a little deformed. Mine is too now. I could not find a formed hose except the 90 degree one.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
hgger69
    • Håkans Motorsida
« Reply #8 on: April 06, 2018, 08:32:20 PM »
Kelley, it’s not deformed att all but there no molded hose for this application, just a normal hose that’s slightly bent to connect the pump and manifold! ;)
Hakan from Sweden
