Author Topic: 8N337153 MQ 396 block (hurt)  (Read 7784 times)
« on: March 28, 2018, 03:38:58 AM »
1968 Camaro Big Block Chevy BBC 396 375hp MQ 4 Bolt Block 3916323 323 J-12-7 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F332581306854
Re: 8N337153 MQ 396 block (hurt)
« Reply #1 on: March 29, 2018, 05:34:21 PM »
That's a $500/210lb protect-o-plate..
« Reply #2 on: March 29, 2018, 06:50:27 PM »
I tend to agree. I am not sure I would want to deal with having that fixed. Unless I owned the car...
« Reply #3 on: March 29, 2018, 07:16:13 PM »
If I had the Car, build a CE L78 Motor and then take this Cylinder-Block and manufacture a glass topped coffee table ,,,,,
I concur it is almost only worth something to the owner of that VIN,
« Reply #4 on: March 29, 2018, 07:33:59 PM »
I'm curious what cased the block ends to break off.
Never had seen that before even on abused motors.
Kelley W King
« Reply #5 on: March 29, 2018, 08:31:47 PM »
I have seen it before. Clutch exploded. That what scattershields are for. Car might be easy to find. Holes or big dents in the floor.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #6 on: April 02, 2018, 02:38:14 PM »
I think you are right. It was some type of clutch/pressure plate/flywheel failure that caused the damage.  And people need to remember to also run the block plate when the run a scatter shield.  It's good insurance.
« Reply #7 on: April 02, 2018, 06:06:37 PM »
I wouldn't be afraid of that block. Sleeves are a fine option. If I had a 8N337xxx and was NOM, I'd run that......
« Reply #8 on: April 02, 2018, 06:36:42 PM »
Sleeves usually are not a problem.
The areas in the rear where it was damaged and repaired (both sides) are what I would be worried about.
70L34
« Reply #9 on: June 09, 2018, 09:39:39 PM »
Looks saveable if you wanted to save it.
« Reply #10 on: June 09, 2018, 11:30:21 PM »
Looks like it was welded with a nickle rod. I don't like the porosity, it could leak oil under pressure.
