Author Topic: Warranty Engines  (Read 60239 times)
Re: Warranty Engines
« Reply #45 on: May 19, 2015, 04:35:50 AM »
I *think* you meant that '.. 302's ONLY come from Flint'...  but Flint did build other engines than 302's.. :)
PS.  I suspect the engine discussed (a *supposed* 302 CE engine built in Tonawanda) was NOT really assembled in Tonawanda 'as a 302', but instead someone found a compatible CE block (ie. a 327 ?)  from Tonawanda and *built* the 302 from it for their Z28...  (purely speculation, but it's the only way I can think of for the facts to be as presented)...
Yep.
rsr
« Reply #46 on: May 19, 2015, 12:01:47 PM »
Exactly what I said and meant that 302s came from Flint.......simply wondering how a supposed NOS CE302 with the correct parts has a Tonawanda number and you have a good theory as to why! If someone bought just the block over the counter to build could it have come from Tonawanda? Thanks..........
BSMIT59
« Reply #47 on: May 19, 2015, 01:02:59 PM »
This is a really confusing issue. I have a 2657 casting with a CE stamped pad. The # is  CE823512   Nothing else stamped on the pad. I bought it to put in my 1967 4P car. It has the forged crank and popup pistons, but I haven't really done anything with it yet. Any thoughts on what it might be.
Barry     Old guy but still learning.....
Unrestored 67 barn find
67 SS 350 in process  ( in paint booth now)
Looking for 7N243673 to reunite V0320MO block and crank
« Reply #48 on: May 19, 2015, 01:18:36 PM »
Easy now.  Your wording was a bit confusing, at least to me.  302s were only produced at Flint, but Flint did produce other engines.
And the answer to your question, I believe is "YES".
« Reply #49 on: May 19, 2015, 01:21:48 PM »
No way to tell for sure what it is or was just based on the CE number.  Does it have forged 302 crankshaft and forged 302 GM pistons?
BSMIT59
« Reply #50 on: May 19, 2015, 01:27:23 PM »
I'll try to do some more research looking for crank casting and piston stamps this weekend. If i remeber right back when the pan was off, it's a 2690 crank.
« Reply #51 on: May 19, 2015, 07:47:31 PM »
If the number on the crank is 2690, that is a 3.48 inch long stroke crank, so it's a 350.
