Author Topic: testing brake booster  (Read 5421 times)
Randy Shanks
« on: March 25, 2018, 05:39:15 PM »
Is there any way to test the brake booster without the engine running?
Could I use a vacuum pump to test.  Any help would be appreciated.
Randy
1969 Camaro, SS 396, 4 speed, convertible, Hugger Orange w/ white top and interior.
Bought New in summer 1969
m22mike
Re: testing brake booster
« Reply #1 on: March 26, 2018, 06:49:31 PM »
I have rebuilt a bunch of boosters and  always test them with a Air conditioning vacuum pump I used to pull a vacuum on the system.
X66 L78 M22 4.10 Deluxe Threads, PNT 10/10, Red Hockey stripe
Randy Shanks
« Reply #2 on: March 27, 2018, 02:17:28 AM »
would you care to give me the procedure.
Randy
m22mike
« Reply #3 on: March 30, 2018, 12:56:58 AM »
Just hook up a hose with the check valve installed and make sure the rubber cup seal is in place along with the rod that is installed in the front. With vacuum applied push in the rear rod in small steps . You input will match the output travel.
Randy Shanks
« Reply #4 on: March 30, 2018, 01:34:32 AM »
Thanks m22mike
Randy
