Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
testing brake booster
« previous
next »
Print
Pages: [
1
Author
Topic: testing brake booster (Read 5417 times)
Randy Shanks
Member
on:
March 25, 2018, 05:39:15 PM »
Is there any way to test the brake booster without the engine running?
Could I use a vacuum pump to test. Any help would be appreciated.
Randy
Tweet
Logged
1969 Camaro, SS 396, 4 speed, convertible, Hugger Orange w/ white top and interior.
Bought New in summer 1969
m22mike
Member
Re: testing brake booster
Reply #1 on:
March 26, 2018, 06:49:31 PM »
I have rebuilt a bunch of boosters and always test them with a Air conditioning vacuum pump I used to pull a vacuum on the system.
Logged
Randy Shanks
Member
Reply #2 on:
March 27, 2018, 02:17:28 AM »
would you care to give me the procedure.
Randy
Logged
m22mike
Member
Reply #3 on:
March 30, 2018, 12:56:58 AM »
Just hook up a hose with the check valve installed and make sure the rubber cup seal is in place along with the rod that is installed in the front. With vacuum applied push in the rear rod in small steps . You input will match the output travel.
Logged
Randy Shanks
Member
Reply #4 on:
March 30, 2018, 01:34:32 AM »
Thanks m22mike
Randy
Logged
Print
Pages: [
1
« previous
next »
Maintenance
