I wanted to share a problem that I had and the end result to fix. I had a misfire at 4500 rpm seemed like a lean problem. So I checked the carb, and ended up rebuilding it which was not the problem. Then changed the fuel pump which resulted in me removing the smog pump to get to the fuel pump. Still not the problem. So I changed out the old 293 coil with a Mallory coil that I have had for 24 years. Bingo bad coil. Since I did not have the correct number coil, I ordered a repo coil with the "298" embossed on the part, correct for a 69 Z28. I thought new coil should take care of the problem. Nope, same misfire at 4500 rpm. Put the old Mallory coil ran great. I thought maybe my plug wires had aged so put in good relatively new wires with the new 298 coil...misfire. So this told me the coil was bad for sure. So put the Mallory coil back in the car, and then put the crappy "correct" date coded Packard wires back on. Car runs great now. But previously I had the old 293 coil on the car with the Packard wires and the car ran fine. Just over the time has this problem surfaced. So I am wondering if I still have a problem masked by the better high output coil?
