Author Topic: 5 numbered Rochester carburetors  (Read 5399 times)
opelitis1
« on: March 01, 2018, 02:07:07 PM »
Have  29202  +  29251  Rochester 1969  carburetors ..  Notice the "70" is missing from the units.    Anyone explain what engines / car models
these units are from, and why the 5 numerics instead of the common "70" numbered carbs. The Julian dates are;   098 9   and  114 9  respectively?
Thanks!
Ted
Kelley W King
Re: 5 numbered Rochester carburetors
« Reply #1 on: March 01, 2018, 04:01:13 PM »
One of Hemmings mags had a really extensive Qjet id article a couple months ago.. You might google it or I could look tonight. It explained all the numbers in detail.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
OG69Z
« Reply #2 on: March 01, 2018, 07:15:21 PM »
Not sure about those numbers missing the 70,but assuming they should be there:
29202: 300HP 350 auto trans Chevy
29251:  69 Olds 400/455 base engines
Hope this helps!
« Reply #3 on: March 02, 2018, 01:03:48 PM »
Out of curiousity - are any of the carbs marked "Rochester by Carter" in the logo ? I have a Rochester with a 5 digit number that was evidently made by Carter, either as a sourced part or a marketing/licensing agreement. Worth a look -
Another explantion or possibility might be a service part, covering multiple applications.
« Reply #4 on: March 04, 2018, 05:37:18 PM »
If you have Chevrolet by the Numbers 1965-69, there's a good explanation about the missing "70" in the Rochester carb section, also date coding and marking of the carbs. Very helpful -
opelitis1
« Reply #5 on: March 21, 2018, 01:35:10 PM »
Thanks for the replies!!   I'll check further on the 2 carbs I have.
Ted
